Intel® Makers
9872 Discussions
Delete Catalog item from IoT Analytics Dashboard
AReil1
How do you delete a component / catalog item from the dashboard? And is there any way to rearrange the order in the catalog dashboard?
Community Manager
Hi techsodb,
I confirmed that it's not possible to delete just one component, you would have to use "iotkit-admin reset-components" to delete the components, but this command will delete all the components so be careful when using it.
Additionally, there is no way to rearrange the order in the catalog dashboard. The only way would be clearing the catalog by deleting the account and re-create it, activate the devices and register all the components, which means that you will lose all the data and start fresh.
Diego
Community Manager
Hi techsodb,
You can use the following command to delete the current components: reset-components. However, it'll delete all the components. If I'm not mistaken, there is no way to delete just one component, or to rearrange the order in the catalog dashboard.
I'll try to find additional information about it. If I'm able to find some additional detail, I'll post it here.
Diego
Community Manager
Hi techsodb,
Diego
