Intel® Makers
9868 Discussions
Detect if USB cable is connected to ttyGS0?
CChri35
New Contributor II
Hi!
I'm intending to run an application on the edison which gets user input of a textfile which lies on the mass storage
partition that shows up when e.g. a windows machine is connected. The intention is that everybody can edit this file
easily and after plugging of the USB cable and rebooting the edison a c++ app mounts the partition, reads out the
textfile and uses the infos out of it. The c++ app is started automatically when the edison boots and mounts the partition.
The problem is that when the partition is mounted with
losetup -o 8192 /dev/loop0 /dev/disk/by-partlabel/update
mount /dev/loop0 /update
... the USB port disconnects and thus the user on the windows machine can't edit anything anymore. How can
I detect programmatically (or over any shell command) that the ttyGS0 port is used?
the optimum would be to recognise the USB connection in a loop and wait for it's disconnection.
Thanks!
Pedro_M_Intel
Hello Christoph.P,
I believe the script found in https://github.com/MakersTeam/Edison/blob/master/Python-Examples/USB/USBCheckStatus.py Edison/USBCheckStatus.py at master · MakersTeam/Edison · GitHub might be just what you were looking for. There is still some optimizations needed to be done, but you can base your project on this script.
Peter.
Pedro_M_Intel
Hello Christoph.P,
Peter.
CChri35
New Contributor II
Thank you very much!
That was indeed I was looking for!
Pedro_M_Intel
I'm glad to hear that, it's great to be of help. If you ever encounter any other issue, don't hesitate to come back to the community.
Peter.
jhane2
Generally, I don't think it is a good idea to have two host trying to be the master of the same device at the same time. This may be why windows disconnects. I can do this with a linux host, double mounting, but there seems to be an inconsistency with the contents of the file.
jeff
