Community
cancel
Showing results for
Search instead for
Did you mean:
BHerr2
Develop on Arduino kit but embed using mini breakout board?
Jump to solution
I understand that the GPIO pins using the Edison Arduino kit operate at 5V but the mini breakout board can only do 1.8V. But is it good practice to do early prototyping on the arduino kit to have access to all the gpio pins and then transfer the edison module to the smaller breakout board and solder on the pins you need?
Diego_V_Intel
Hi herrerab,
That approach might work if the prototyping is very simple, but I don't recommend it. When the Edison module is programmed, the expansion board where it is connected to is considered when the muxes are configured. If you program the Edison using the Arduino Expansion Board, when you transfer the module to the Mini-Breakout Board you will probably get errors during execution because there are some muxes that are only available on the Arduino Expansion Board. Additionally, if you base your prototyping on the logic level of 5V used by the Arduino Expansion Board, then you will have to add a voltage level interface to the Mini-Breakout Board because its logic level is 1.8V.
Anyhow, if you are planning to use the Mini-Breakout Board at some point, then why don't solder all the pins and prepare the board for prototyping right away? That way you will be doing the prototyping using the Mini-Breakout Board and you will be sure that it'll work.
Diego.
Diego_V_Intel
Hi herrerab,
Diego.
