Intel® Makers
9882 Discussions
Difference between STK1AW32SC and STK1AW32SCR?
RS_1
hello guys,
can you please tell me the difference between
STK1AW32SC and
STK1AW32SCR ?
the tec specs on intel website are the same but the price is different: http://www.intel.com/buy/us/en/catalog/compare/507162/501535 http://www.intel.com/buy/us/en/catalog/compare/507162/501535
thanks and greetings from germany
Ronny_G_Intel
Community Manager
Hi Shortyfilms,
On previous post added by Hellen the information is partially answering your question as it only refers to STK1AW32SCR and changes on that product only.
The letter "R" at the end of the product code: BOXSTCK1A32WFCR or STK1AW32SCR as you mentioned was just appended to the product code to reflect 1st phase (internal calendar). Only difference is that later devices (for instance the BOXSTCK1A32WFC) have additional regulatory logos on the labels and in the collateral. There are no design or functional differences.
I hope this helps,
Ronny G
Community Manager
Hi Shortyfilms,
Please check on the Intel® Compute Stick STK1AW32SC's product change notification document, you would find that later versions of the STK1AW32SCR (SA H93322-103) will run an updated Windows 10 Home Build 1511 along with driver updates.
Here is the PCN 114303-00 information:
https://qdms.intel.com/Portal/SearchPCNDataBase.aspx?mm=946467 https://qdms.intel.com/Portal/SearchPCNDataBase.aspx?mm=946467
If there is anything else you need, please let me know.
Hellen.
Ronny_G_Intel
Community Manager
Hi Shortyfilms,
I hope this helps,
Ronny G
RS_1
Thank you very much for the information!
I was confused that there are 2 sticks with different prices on your shop website, one with and one without the "R" ...
So i should chose the cheaper one if there are no technical differences ;-)
