Hi all,
I have been struggling to put an HTU21DF at work with my edison Arduino Breakout.
Preliminary observation :
if I use the Arduino IDE with sparkfun HTU21DF example everything is OK, readings are always correct and display on the serial is always nominal
What I tried to do :
I cloned on my Edison the git repositories mraa and upm compiled and installed the programs.
I used the functions provided by upm library (some are missing compared to IDE example but that's not my point)) from python program. It worked like a charm (or almost see another post dealing with the consequences of a throw command added in mraa). But when I tried to execute the same python program without direct USB connection with the board (I used WIFI connection) then the measurements were wrong and it was like the Edison could not access the i2c bus
Symptoms :
I am connected to the Edison through WIFI on my personnal network. (I have commented the throw exception in mraa)
- If the breakout is connected with USB connectors my program calling upm/htu21d functions works well and provide stable measurements
- If I add the external power on the J1 barrel connector, reboot and restart the program it is unstable; at times I get wrong measurements and in some cases it does not recover if I try a test or reset I get : no change / errors/ crash.
- If I boot with barrel power only I got bad measurements just like it was not possible to reach the bus.
Am I missing something or is there a bug or possible hardware problem ? My power supply is on 9v (27VA)
Let me know what I can provide if needed to explore this problem.
Annex problem/question I have not been able to change the readings from HOLD to NO_HOLD could it be the reason why if I put my HTU21D with other sensors on the bus and use this hu21D-upm Nothing works any more.
Many thanks.
Hi Gerard,
You should be able to read data whichever the method you use, as long as the voltage in the power supply is inside the range supported (7V to 15V).
Is this happening only with the python code? Or is it happening with the Arduino Code too?
I do not have the same sensor you have but I will do some tests in order to check if I get the same behavior.
Have you noticed other problems in the board related to power? Maybe with other interfaces while using a power supply?
Is this the only board you have? If you have another one we could test the code and sensor in order to see if the problem is related to the hardware of the board.
Charlie
Hi Charlie thanks for the suggestion
I have borrowed an edison with Arduino breakout from a friend and that one works perfectly with external power or USB power.
According to your guess this may demonstrate that it must be an hardware problem then ...
Do you think the problem may come from the arduino board or the Edison itself ?????
I do not know how to compile the arduino code straight on the edison (without usb connection and without IDE) mainly because I cannot find Wire.h and Wire library containing Wire functions used in the arduino code.
Another disturbing point is that I need to comment out the "throw" instruction from mraa/api/mraa/i2c.hpp (and go back to situation before commit)
readReg(uint8_t reg){int x = mraa_i2c_read_byte_data(m_i2c, reg);/* if (x == -1) {throw std::invalid_argument("Unknown error in I2c::readReg()");}*/return (uint8_t) x;}I have tried many ways to try/catch the error message sent but in all solutions I have tested, It cannot read read the second byte freom the bus to build the measurement value. I can successfully pass the try but the values sent are wrong, Maybe I am not catching properly ..... Here is the htu21d.cpp amendments :
uint16_t
HTU21D::i2cReadReg_16 (int reg) {
uint16_t data;
m_i2ControlCtx.address(m_controlAddr);
try {
data = (uint16_t)m_i2ControlCtx.readReg(reg) << 8;
catch (const std::invalid_argument& e )
data = 1;
fprintf(stdout, " Failed to read first byte with readReg at address : %d" , reg);
try {
data |= (uint16_t)m_i2ControlCtx.readReg(reg+1);
data = 1;
fprintf(stdout, " Failed to read second byte with readReg at address : %d\n", reg+1);
return data;
Finally I tried to use 3 sensors on the same i2c bus HTU21D-F BMP180 MPL115A2 , it works perfectly on the arduino board but no way with the edison !!!! even the HTU21D-F is not visible. Using the IDE with the Edison the message is "cannot find sensor" and when trying straight on the Edison messages are :
Executing Sensor Test
Traceback (most recent call last):
File "HTU21DF.py", line 66, in
messureTempHygro()
File "HTU21DF.py", line 34, in messureTempHygro
test()
File "HTU21DF.py", line 23, in test
htu21df.testSensor ()
File "/usr/lib/python2.7/site-packages/pyupm_htu21d.py", line 257, in testSensor
return _pyupm_htu21d.HTU21D_testSensor(self)
ValueError: UPM Invalid Argument: i2cWriteReg: mraa_i2c_write() failed
File "tempPress.py", line 17, in
bmp180 = pyupm_bmpx8x.BMPX8X(bus, pressAddress)
File "/usr/lib/python2.7/site-packages/pyupm_bmpx8x.py", line 170, in __init__
this = _pyupm_bmpx8x.new_BMPX8X(bus, devAddr, mode)
RuntimeError: UPM Runtime Error: BMPX8X: Invalid chip ID
Any suggestion
Gérard
You said that the edison is working on the USB power but not using the barrel jack. You also tried a battery and another arduino-edison plattform.
So you can say:
- the sensors are fine
- the edison is ok (to be shure you can try your friends breakout with your edison)
- the power supply is ok (the battery was to try out if the source ripple is to high)
-> if you now look at the arduino breakout schematics on page 3 ( http://www.intel.com/content/dam/support/us/en/documents/edison/sb/edison_arduino_hvm_8_26.pdf http://www.intel.com/content/dam/support/us/en/documents/edison/sb/edison_arduino_hvm_8_26.pdf )
you can see the different current path refering to different power supplies.
The first time both ways (USB power / Barrel Jack) cross is at the 5 V label. This is after the diodes CR1 / CR2.
So I suppose there must be something wrong with the regulator U1 and its circuit.
So you can try the following:
- use the arduino breakout 5 V connection as 5 V input (this should be quite accurate 5,0 V, lets say +/- 0,2 V, do not use any other power supply!)
--> this should work, your sensors should behave as using the USB port as power supply
- use the arduino breakout VIN connection and supply 9 V (battery or anything else)
--> I suppose this will not work
Keep us up to date.
Flo1991
Hi Flo1991 Thanks for the follow-up
So you can say:
YES I can say that plugged on a standard arduino UNO they yield acceptable measurements even when plugged all together
I CANNOT CONFIRM I WILL CHECK I have not tested my Edison on his Arduino breakout I will do it (as soon as I come back home I am at a conference at the moment)
YES I tested it also with a multimeter its is stable and nominal
I do not understand you mean I have to use 5v instead of 3.3V to power the sensors? Or I use th other arduino to power the faulty one?
Iwill check and let you know if the Edison or the breakout is faulty.
Thanks again
edit 2016-07-12
Sorry for the delay I was out for a conference last week.
to answer @charlie I am doing the changes in i2C.hpp then rebuild the library
To sum up my arduino board is faulty and my Edison seems to work like the other one when it is on the other board.
But when I have double checked the other Edison on my supposed faulty board it works properly and when I have triple checked by putting back my Edison on my board confirming that the board is faulty and probably the Edison is not at its best condition.
To conclude and close this thread if you agree
The strange behavior identified is due to an hardware problem.
Another result is that it is more difficult to get the i2c sensors running with the Edison/Arduino than with the Arduino. My goal is to demonstrate the power and the immense opportunites of SOC and IoT compared to microcontrollers which is clearly possible with GPIO using controlled leds or analogic sensors but for the i2c with digital sensors some important problems have to be solved... I have finally ordered a new Edison to tackle these difficulties.
Testing report
First of all I have tested the sensors on an arduino to be sure they are OK. There are four sensors 2 HTU21D-F BMP180 MPL115A2, I have put 3 of them on the same bus and I get the following measurements (the firts values are with the first HTU21D and the second with the other) :
Time:636985
MPL115A2Press : 997.6128 hPa
MPL115A2Temp : 20.3 degC
HTU21DTemp : 24.6 deg C ; Humidity:52.1 %
BMP180Temp : 24.99 deg C ;
BMP180Press : 995.53 hPa,
relative (sea-level) pressure: 1015.71 hPa, computed altitude: 169 meters,
Time:706274
MPL115A2Press : 998.0930 hPa
MPL115A2Temp : 20.5 degC
HTU21DTemp : 25.0 deg C ; Humidity:50.5 %
BMP180Temp : 25.02 deg C ;
BMP180Press : 995.61 hPa,
relative (sea-level) pressure: 1015.79 hPa, computed altitude: 169 meters,
There is a difference between the two Temperature measurements.... But those are microsensors . When I plug/unplug the sensors on the breadboard everything keeps on working, the remaining sensors providing measurements.
When I connect to Edison/Arduino A to the same wiring the measures from HTU21D are wrong while the other are correct ! If I unplug the MPL sensor measures become correct from the HTU21D which is really weird
Time:581080
MPL115A2Press : 996.8079 hPa
HTU21DTemp : 998.0 deg C ; Humidity:998.0 %
BMP180Temp : 25.03 deg C ;
BMP180Press : 995.46 hPa,
relative (sea-level) pressure: 1015.64 hPa, computed altitude: 169 meters,
After removing HTU21D
Time:586271
MPL115A2Press : 86.6744 hPa
MPL115A2Temp : -73.1 degC
HTU21DTemp : 24.8 deg C ; Humidity:52.6 %
BMP180Temp : 25.05 deg C ;
BMP180Press : 995.50 hPa,
relative (sea-level) pressure: 1015.68 hPa, computed altitude: 169 meters,
With2 sensors only
Time:5517
MPL115A2Press : 997.2876 hPa
MPL115A2Temp : 20.7 degC
BMP180Temp : 25.01 deg C ;
BMP180Press : 995.18 hPa,
relative (sea-level) pressure: 1015.35 hPa, computed altitude: 169 meters,
When I connect to Edison/Arduino B The BMP180 cannot initialize and yields bad measurements, if I unplug the MPL BMP180 works but in all cases I get bad measurements for HTU21D except if it is alone on the bus (I have unplugged the MPL for the last measurements). If HTU21D is removed BMP180 initializes properly.
Time:55038
Time:183038
HTU21DTemp : 24.4 deg C ; Humidity:53.4 %
Time:40673
MPL115A2Press : 997.4396 hPa
MPL115A2Temp : 21.1 degC
BMP180Temp : 25.35 deg C ;
BMP180Press : 995.20 hPa,
relative (sea-level) pressure: 1015.38 hPa, computed altitude: 169 meters,
As a conclusion to this step the boards used with the arduino-IDE give different results but more annoying : it is impossible to get the normal(identical toa true Arduino) behaviour with both boards and three sensors. To get correct measurements from HTU21D it must be alone on the bus... There is something wrong with the i2c provided by the Edison/Arduino with these sensors. I have not enough competencies in electronics to investigate further.
Trying now to acces the Edison through WIFI and communicate to the sensors with mraa/upm libs (no mpl115A2 is available and I had no time to convert one from the web)
I am still on board B
Without touching the wiring If I collect the measurements on BMP180 with mraa/upm I get correct values
If I plug the barrel power nothing changes
If I unplug the USB nothing changes
If I reboot the Edison (from wifi connection) in this situation (no USB connected)
I get again correct measurements for BMP180
Concerning HT...
Can you provide more information about your power supply?
Try a 9 V battery instead of a power supply, is the problem solved using a battery?
Flo1991
Thanks Flo1991 I have checked and
I can reproduce exactly the same problem with 9V Battery.
The power supply can deliver 3 4 5 6 7 9 12 V power available is 27VA which express I think that I can get up to 3A with 9V setting.
Gérard.
Hi Gerard,
I'm glad to know that you were able to identify the problem, let us know the outcome of running the suggestions from Flo1991. You can contact the store where you bought the module/board/kit and see if they offer a warranty policy. If the store do not offers a warranty policy or the limited time for it has expired you can contact Intel Support http://www.intel.com/support/mailform/maker/warrantyemail.htm http://www.intel.com/support/mailform/maker/warrantyemail.htm.
In order to run a sketch without using the COM port, you can use the service from older releases that loads the latest sketch, you will need to use the workaround from: /message/319509# 319509 https://communities.intel.com/message/319509# 319509
Are you doing the changes in /usr/include for the i2c.hpp or are you building the library?
Let us know about your results.
Charlie
Hi Gerard,
I would like to know if you have been able to test if the problem was the board or module, also if you contacted the store or opened a ticket.
Let us know the results.
Charlie
Please see edit and final proposal upstream.
Thanks to all
