Intel® Makers
9881 Discussions
Disabling default edison web server while creating the image
SR11
I understand how to disable the default webserver after logging into the OS. But, how can I disable it while creating the image?
Srikanth
Diego_V_Intel
Hi Blackhole,
In order to disable the default web server you have to remove the package "oobe" from this layer/recipes group: edison-src/meta-intel-edison/meta-intel-edison-distro/recipes-support/
Diego
Diego_V_Intel
Hi Blackhole,
I'm not sure but let me investigate about it. I'll post any information I find as soon as possible.
Diego
Diego_V_Intel
Hi Blackhole,
Diego
SR11
Hi Diego,
Thank you..
Let me try and get back with the result.
Srikanth
SR11
When I remove oobe, won't it effect the entire edison_config_tools which includes other services like password, wifi etc.?
Diego_V_Intel
Hi Blackhole,
I haven't tested it, so I'm not sure if removing the package will affect the entire edison_config_tools. On the other hand, the default web server script is edison-config-server.js, so you could try to remove only this script from the installation.
As you can see here: http://git.yoctoproject.org/cgit/cgit.cgi/meta-intel-edison/tree/meta-intel-edison-distro/recipes-su... meta-intel-edison - Layer for the Intel Edison Development Platform, the installation of the web server script is in the line 48. I suggest you to comment this line and try to build the image.
Diego
