Intel® Makers
9867 Discussions
Discover bluetooth devices (beacons) on the Intel Edison module?
SZ2
Greetings.
I would like to know if there is anyway to discover bluetooth devices (beacons for instance, iBeacon/Eddystone) "programmatically", or automatically. So far I have used the bluetoothctl to scan and discover for instance my Android phone, which I successfully paired with. The idea is to let the Intel Edison module discover beacons and then propagate this trigger to for instance an Android app. The communication between the module and phone is already working, but the scanning for beacons is missing.
I was thinking that maybe there is a way to do this with Python?
All help is greatly appreciated!
Community Manager
Hello zettez,
If you would like to use Python to interact with BLE devices (such as beacons), you could use pygattlib ( https://bitbucket.org/OscarAcena/pygattlib). You will need to install boost and gatttool as pygattlib depends on them. I suggest you to follow the instructions provided by Charlie in https://communities.intel.com/message/396737# 396737 https://communities.intel.com/message/396737# 396737 in order to install pygattlib and its dependencies.
I hope this information helps you, I'll be glad to help if otherwise.
-Peter.
SZ2
Thank you, but I cannot get this to work. I did follow the guides how to install the boost and gatttool, but when I try to run some code from the sample page:
from gattlib import DiscoveryService
service = DiscoveryService("hci0")
devices = service.discover(2)
for address, name in devices.items():
print("name: {}, address: {}".format(name, address))
Then I get this error:
root@edison:/home/bluetooth# python discovertest.py
Traceback (most recent call last):
File "discovertest.py", line 1, in
ImportError: libboost_python.so.1.58.0: cannot open shared object file: No such file or directory
It looks like the boost library did not get installed correctly?
Community Manager
Hi zettez,
I'm currently installing boost, as soon as I finish I will install gatttool and pygattlib. I will try to replicate the issue. I will update you once it finishes installing.
-Peter.
Community Manager
Hi zettez,
These are the steps I took to correctly install pygattlib:
wget http://sourceforge.net/projects/boost/files/boost/1.58.0/boost_1_58_0.tar.gz
tar -zxf boost_1_58_0.tar.gz
cd boost_1_58_0/
./bootstrap.sh
./b2 install
cd
wget https://www.kernel.org/pub/linux/bluetooth/bluez-5.24.tar.xz --no-check-certificate
tar -xf bluez-5.24.tar.xz
cd bluez-5.24
./configure --disable-systemd --disable-udev
make
make install
cd
pip install gattlib
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/lib/
After this I was able to run the following code without any issues:
Let me know if this helps you.
-Peter.
SZ2
I am sorry for all the edits, I successfully made it all work in the end.
Thanks for all the information.
Some notes how I made this all work:
* The environment "export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/lib/ " is super important. I never saw this one in any other guide. Having this in my path fixed the boost problem. It should really, really be added in the other post you linked to me.
* After I reflashed I had to do the "rfkill unblock bluetooth" to enable bluetooth
Again, I want to thank you for the help!
Community Manager
Hi zettez,
I'm glad to be of help, if you ever have any other doubt, please don't hesitate to come back to the community.
-Peter.
