Intel® Makers
9881 Discussions
Disk Expansion in intel edison
hmuja
I am using intel ediosn for iot apps development. I am running out of disk space and i want to expand it using SD card. Is there some guidance or tutorial for this?
Community Manager
Have you tried to resize the partitions of the image? Look at these links:
http://alextgalileo.altervista.org/blog/changing-partition-setup-edison/
http://www.instructables.com/id/Yocto-Customization-1-Increase-Root-Partition-Size/
If you want to boot from the SD card and use the available space in it, I suggest you to look into: https://communities.intel.com/thread/61048 https://communities.intel.com/thread/61048
Charlie
Community Manager
Charlie
