Community
cancel
Showing results for
Search instead for
Did you mean:
JTurn12
New Contributor II
Disk Space on Galileo
I am having trouble installing packages etc on the Galileo due to disk space. I feel there's an error because I do have a 32Gb card.
I'm sure there's a catch or something very basic I am not knowledgable about
Here is the result of df -h
root@galileo:~# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 1.3G 1.2G 5.1M 100% /
devtmpfs 116M 0 116M 0% /dev
tmpfs 116M 0 116M 0% /dev/shm
tmpfs 116M 13M 104M 11% /run
tmpfs 116M 0 116M 0% /sys/fs/cgroup
tmpfs 116M 0 116M 0% /tmp
tmpfs 116M 4.2M 112M 4% /var/volatile
/dev/mmcblk0p1 50M 17M 34M 33% /media/card
How do I go about freeing up some space here?
Tips appreciated!
FTinetti
Honored Contributor I
Tips appreciated!
The problem is that some cards are formatted so that there is only one partition of about 50MB. The line
summarizes it (no matter the length of your SD card, you can use only 50MB). It happened to me and
another thread shows the same problem. I do not know the reason/s. I've solved by repartitioning. Take
a look at
HTH;
Fernando.
FTinetti
Were you able to solve your problem?
Fernando.
