Community
cancel
Showing results for
Search instead for
Did you mean:
cchao6
Does anyone install scipy on edison successfully?
Jump to solution
Hi everyone
Dose anyone install scipy on edison successfully?
Based on Python 2.7 and yocto image 2.1
If you konw how to install it ,can you tell me how to do it or give me some guides?
Chen
Pedro_M_Intel
Hello cer1991,
I installed Numpy (a dependency of SciPy) using Python's pip command. First, you will need to install pip from AlexT's repo. You can find instructions on how to set the repo in http://alextgalileo.altervista.org/edison-package-repo-configuration-instructions.html Edison Package Repo Configuration Instructions.
After the repo is set up, you can install pip with the following command:
opkg update
opkg install python-pip
Then you can install NumPy with the command:
pip install numpy
Once NumPy is installed you can install SciPy, another user had issues installing it but he managed to resolve them, you can see the details in .
Let us know if it helps.
Peter.
Pedro_M_Intel
Hello cer1991,
opkg update
pip install numpy
Peter.
cchao6
Dear @Intel_Peter
Thank you for your help.
I have install 'pip' successfully , but when I install scipy,I meet some probelms as below:
root@myedison2:~# pip install scipy
Downloading/unpacking scipy
Downloading scipy-0.17.0.tar.gz (12.4MB): 12.4MB downloaded
Running setup.py egg_info for package scipy
warning: no previously-included files matching '*_subr_*.f' found under directory 'scipy/linalg/src/id_dist/src'
no previously-included directories found matching 'benchmarks/env'
no previously-included directories found matching 'benchmarks/results'
no previously-included directories found matching 'benchmarks/html'
no previously-included directories found matching 'benchmarks/scipy'
no previously-included directories found matching 'scipy/special/tests/data/boost'
no previously-included directories found matching 'scipy/special/tests/data/gsl'
no previously-included directories found matching 'doc/build'
no previously-included directories found matching 'doc/source/generated'
no previously-included directories found matching '*/__pycache__'
warning: no previously-included files matching '*~' found anywhere in distribution
warning: no previously-included files matching '*.bak' found anywhere in distribution
warning: no previously-included files matching '*.swp' found anywhere in distribution
warning: no previously-included files matching '*.pyo' found anywhere in distribution
Installing collected packages: scipy
Running setup.py install for scipy
lapack_opt_info:
lapack_mkl_info:
mkl_info:
libraries mkl,vml,guide not found in ['/usr/lib']
NOT AVAILABLE
NOT AVAILABLE
atlas_threads_info:
Setting PTATLAS=ATLAS
libraries ptf77blas,ptcblas,atlas not found in /usr/lib
libraries lapack_atlas not found in /usr/lib
numpy.distutils.system_info.atlas_threads_info
NOT AVAILABLE
atlas_info:
libraries f77blas,cblas,atlas not found in /usr/lib
numpy.distutils.system_info.atlas_info
NOT AVAILABLE
/usr/lib/python2.7/site-packages/numpy/distutils/system_info.py:1379: UserWarning:
Atlas (http://math-atlas.sourceforge.net/ http://math-atlas.sourceforge.net/) libraries not found.
Directories to search for the libraries can be specified in the
numpy/distutils/site.cfg file (section [atlas]) or by setting
the ATLAS environment variable.
warnings.warn(AtlasNotFoundError.__doc__)
lapack_info:
libraries lapack not found in ['/usr/lib']
NOT AVAILABLE
/usr/lib/python2.7/site-packages/numpy/distutils/system_info.py:1390: UserWarning:
Lapack (http://www.netlib.org/lapack/ http://www.netlib.org/lapack/) libraries not found.
numpy/distutils/site.cfg file (section [lapack]) or by setting
the LAPACK environment variable.
warnings.warn(LapackNotFoundError.__doc__)
lapack_src_info:
NOT AVAILABLE
/usr/lib/python2.7/site-packages/numpy/distutils/system_info.py:1393: UserWarning:
Lapack (http://www.netlib.org/lapack/ http://www.netlib.org/lapack/) sources not found.
Directories to search for the sources can be specified in the
numpy/distutils/site.cfg file (section [lapack_src]) or by setting
the LAPACK_SRC environment variable.
warnings.warn(LapackSrcNotFoundError.__doc__)
NOT AVAILABLE
Running from scipy source directory.
Traceback (most recent call last):
File "", line 1, in
File "/tmp/pip-build-root/scipy/setup.py", line 265, in
setup_package()
File "/tmp/pip-build-root/scipy/setup.py", line 262, in setup_package
setup(**metadata)
File "/usr/lib/python2.7/site-packages/numpy/distutils/core.py", line 152, in setup
config = configuration()
File "/tmp/pip-build-root/scipy/setup.py", line 182, in configuration
config.add_subpackage('scipy')
File "/usr/lib/python2.7/site-packages/numpy/distutils/misc_util.py", line 1003, in add_subpackage
caller_level = 2)
File "/usr/lib/python2.7/site-packages/numpy/distutils/misc_util.py", line 972, in get_subpackage
caller_level = caller_level + 1)
File "/usr/lib/python2.7/site-packages/numpy/distutils/misc_util.py", line 909, in _get_configuration_from_setup_py
config = setup_module.configuration(*args)
File "scipy/setup.py", line 15, in configuration
config.add_subpackage('linalg')
caller_level = 2)
File "scipy/linalg/setup.py", line 20, in configuration
raise NotFoundError('no lapack/blas resources found')
numpy.distutils.system_info.NotFoundError: no lapack/blas resources found
Complete output from command /usr/bin/python -c "import setuptools;__file__='/tmp/pip-build-root/scipy/setup.py';exec(compile(open(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-nv2x8g-record/install-record.txt --single-version-externally-managed:
lapack_opt_info:
lapack_mkl_info:
mkl_info:
NOT AVAILABLE
</p...
Pedro_M_Intel
I'd suggest you to contact scipy for a more accurate answer. You can contact them in:
https://groups.google.com/forum/# !forum/scipy-user SciPy Google Groups
https://scipy.github.io/old-wiki/pages/Mailing_Lists.html Mailing_Lists - SciPy wiki dump
Peter.
