Community
cancel
Showing results for
Search instead for
Did you mean:
SOOKEONG_O_Intel
Does the Galileo board support automatic power selection or PWR_SEL jumper to draw power from Shield's power source?
Does the Galileo board support automatic power selection or PWR_SEL jumper to draw power from Shiled's power source, instead of power supply cable? Thanks.
AT9
As far as I understand the Galileo Datasheet (/servlet/JiveServlet/downloadBody/21835-102-4-25148/Galileo_Datasheet_329681_003.pdf https://communities.intel.com/servlet/JiveServlet/downloadBody/21835-102-4-25148/Galileo_Datasheet_3...), Galileo doesn't support any form of drawing the power from shields, there are quite a few warnings all across the docs that one must have the power adapter connected at all times.
That's my understanding, those with more knowledge are welcome to chime in.
AT9
@sk5 - if you feel your question is answered, please mark it as such, that will help others with similar problems. If you have any further questions on this - please feel free to bring them in.
SOOKEONG_O_Intel
I was offline for vacation. You're right, the pdf does give the warning. Anyone tried to power the board by reworking the power cable to connect to battery pack (4xAA)?
AT9
I personally haven't tried that, but chofrock mentioned such a use in /thread/47188 this thread
, care to share some details or a link to a discussion on that, if you have it somewhere?
clayton_H_Intel
I have not personally tried connecting AA batteries to the Galileo. I have talked to people who have, and they mentioned that the sketch only continued to run for about 15 minutes.
I would not recommend anyone trying to run off of batteries unless you have a Dediprog in order to reprogram the SPI firmware.
AT9
Thanks for sharing! Alternative could probably be an auto-shutdown watchdog, which would power down the board after battery pack gets below certain voltage.
