Intel® Makers
9880 Discussions
Don't sure about error. How to fix?
RHarc
I pasted the error report that I received. I'm a student trying to learn this, but I can't find a solution. Please help!
I'm also pasting the code that I'm trying to upload to my Arduino. The code is from Sunfounder's website. The site was:
http://www.sunfounder.com/learn/RFID_kit_V1_for_Arduino/lesson-3-interactive-led-flowing-led-lights-...
Error Message:
Arduino: 1.8.1 (Windows Store 1.8.1.0) (Windows 10), Board: "Arduino/Genuino Uno"
collect2.exe: error: ld returned 5 exit status
exit status 1
Error compiling for board Arduino/Genuino Uno.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Code that I wrote (copied):
int ledNum = 8; //the number of the led you attach
byte ledPin[] = {2,3,4,5,6,7,8,9}; //Create array for LED pins
int ledDelay; //delay between changes
int direction = 1;
int currentLED = 0;
unsigned long changeTime;
int potPin = 0; //select the input pin for the potentiometer
void setup()
for (int x = 0; x < ledNum; x++) // set all pins to output
pinMode (ledPin[x], OUTPUT);
changeTime = millis();//
void loop() {
ledDelay = analogRead(potPin); //read the value from the pot
if ((millis() - changeTime) > ledDelay)
{ // if it has been ledDelay ms since last change
changeLED();
void changeLED()
for (int x=0; x < ledNum; x++)
{ // yurn off all LED's
digitalWrite(ledPin[x], LOW);
digitalWrite(ledPin[currentLED], HIGH); // turn on the current LED
currentLED += direction; // increment by the direction value
// change direction if we reach the end
if (currentLED == ledNum-1)
direction = -1;
if (currentLED == 0)
direction = 1;
RHarc
solved the problem. I switched to a different USB port. Not sure why the first USB port din't work but that is a problem for a another day.
Thank you for the help.
FTinetti
Honored Contributor I
Hi DarkHark,
When do you have that error (compile or load time?)
Is your Intel Galileo properly recognized once turned on and plugged in?
Beyond those questions, I think you are trying to use analogRead on pin 0, which does not have an AD converter and is set to OUPUT ...
Fernando.
RHarc
I think it's on compiling. I should have included the fact that it states: Error compiling for board Arduino/Genuino Uno.
That message is in orange just over the error message I wrote first.
As for the second question, I have done other projects successfully. so the Arduino and the computer recognize each other.
Hope that helps you help me.
FTinetti
Try the option "Verify" instead of "Upload".
Please recall to select the proper Intel Galileo card in Tools ==> Board menu so that you compile for the Intel Galileo you have, and remember.
Your computer has to recognize your Intel Galileo regardless whetther you had used Arduino or not.
HTH,
Fernando.
RHarc
FTinetti
good to know,
Fernando.
