Hi all,
Help me please. I need to create a driver of the framebuffer for SPI lcd with controller ILI9341.
I found drivers of the framebuffers for a lot different displays https://github.com/notro/fbtft https://github.com/notro/fbtft, but I codn't integrate it.
I did the same how in the example https://hackaday.io/project/7025/logs https://hackaday.io/project/7025/logs, but I coudn't compile the driver from this example.
If some body did it, help me please, give me example if you have, I can pay if need.
Hi serhiparad,
I will forward your inquiry to our Intel Edison supported group to further assist you.
Rgds,
wb
Up to what point in the guide were you able to successfully follow the steps? What step and command failed to execute? Did you see any error logs, if so, which ones?
Sergio
