Community
cancel
Showing results for
Search instead for
Did you mean:
JJose21
EDISON Drivers wont work on Windows 8.1
I just upgraded my Windows to 8.1 and now the Edison drivers do not work at all.
I already tried https://learn.sparkfun.com/tutorials/disabling-driver-signature-on-windows-8/disabling-signed-driver... Disabling the Driver Signature Enforcement described in Sparkfun.
Any ideas?
Content of the Install Log:
x64 os
Windows version: 8.1
CertMgr.exe MFLD_USB_driver_cert.cer returned 0
Installing drivers, please wait
drvinstall.exe intc_usbcomp.inf returned 0
drvinstall.exe intc_rndis.inf returned 0
drvinstall.exe intc_cdcserial.inf returned 0
drvinstall.exe intc_dfu.inf returned 0
x64 os
x64 os
x64 os
x64 os
x64 os
x64 os
Tags (1)
Sergio_A_Intel
Have you tried installing the drivers from scratch? If you haven't try installing them again. You can try using the Integrated installer found here https://software.intel.com/en-us/iot/hardware/edison/downloads IoT - Intel® Edison Board Download | Intel® Developer Zone .
Also take a look at https://software.intel.com/en-us/get-started-edison-windows-step2 IoT - Step 2: Run the integrated installer | Intel® Developer Zone
Sergio
JJose21
@Intel_Alvarado,
This is what I got from following the "Integrated Installer procedure" there...
Intel® Edison is now installed
Errors detected during installation. Some components failed to process:
Now that you are done installing your drivers, updating the firmware on your board, and installing your IDE, continue by setting up your serial terminal .
JJose21
and... it doesnt work
Sergio_A_Intel
Try with the Flash Tool Lite.
Go to https://software.intel.com/en-us/iot/hardware/edison/downloads IoT - Intel® Edison Board Download | Intel® Developer Zone and download the latest Edison image, labeled "Release 2.1 Yocto complete image".
Then, download the Flash Tool Lite for your OS and install it. In this link https://software.intel.com/en-us/articles/flash-tool-lite-user-manual IoT - Flash Tool Lite User Manual | Intel® Developer Zone you can find instructions on how to install it and flash your Edison with the latest image.
Sergio
Carlos_M_Intel
Hi crmakers,
Have you been able to use the board in Windows 8.1?
Charlie
JJose21
Yes. Thanks for following up.
It was an issue with Windows 8,1 image I got installed in my laptop.
We rebuilt it from scratch and now it is working like a charm.
On the other hand still flashing last firmware to the Edison is cumbersome. I have not done so,but it works fine with the WW15 image I have.
--jn
