Intel® Makers
9882 Discussions
EMIC2 text to speech on Edison?
ccare3
Does anyone know if it's possible to use the EMIC2 text to speech module with the Intel Edison?
Community Manager
Unfortunately, this shield hasn't been officially tested yet. You can see all the shields that have been tested in this document: http://www.intel.com/content/dam/support/us/en/documents/Galileo-Edison_ShieldTestReport_330937-002.... http://www.intel.com/content/dam/support/us/en/documents/Galileo-Edison_ShieldTestReport_330937-002....
I checked the information about this shield, it uses Serial Communication at 9600bps and 8N1, you can get this with your Edison. The next step would be the libraries, I saw there are some Arduino examples, you can try with this but as you may know the Edison do not has the same libraries the Arduino has because they have different hardware and architecture so there could be some conflicts, if this is the case I suggest you to use the MRAA library to control the pins with the API.
http://iotdk.intel.com/docs/master/mraa/ http://iotdk.intel.com/docs/master/mraa/
https://github.com/intel-iot-devkit/mraa https://github.com/intel-iot-devkit/mraa
Charlie
Community Manager
Charlie
ccare3
Charlie,
Thanks for providing this information. The EMIC 2 examples use the SoftwareSerial.h library which, as you correctly point out, is not supported on the Edison board.
I will use the MRAA library and see how I get on.
Carey
