On the first reboot after following the instructions at https://software.intel.com/en-us/flashing-the-bios-on-joule IoT - Flashing the BIOS | Intel® Software , the following error is produced:
Board Name = Joule DVT2
MRC REVISION ID 1.52.27
MMRC REVISION ID 1.09
ERROR: C40000002:V10D0005 I0 A0C98B77-CBA5-4BB8-993B-4AF6CE33ECE4
BIOS ID = GTPP131A.X64.0143.B30.1609232056
Is this to be expected?
Hello josephwinstoniii,
Thanks for reaching out!
I just followed the same guide as you to flash my Joule's BIOS and I'm not able to replicate this behavior. So, my suggestion is that you start over and try to flash your Joule's BIOS again.
Try this and let us know if the error still appears.
-Peter.
I've tried multiple flashing of the BIOS but the message still appears.
Hi josephwinstoniii,
We need you to provide us the following information:
When flashing your Joule's BIOS, did you use a USB 3.0 port or a USB 2.0 port?
Were you using the USB cable included with your Joule or did you use a different USB cable?
Have you tried flashing your Joule's BIOS on a different PC? If so, did you notice any difference?
Let us know.
-Peter.
Perhaps try waiting a bit longer? When I re-flash the BIOS, it usually produces an error, and goes on like that for a few minutes before moving on and booting successfully. It doesn't take more than 4 minutes.
Do you have any updates about this?
-Peter.
This error message should only happen on the first reboot after flashing the BIOS. You should not see this error on subsequent reboots.
