Intel® Makers
9881 Discussions
EXT4-fs error (device mmcblk0p8) on Edison after flash
CMori2
Hello everyone
I am pretty new with the Edison so I have been playing with it and flashed a few times. Loggin in with putty I see several lines like this
[ 589.382151] EXT4-fs error (device mmcblk0p8): ext4_lookup:1437: inode # 7020: comm node: deleted inode referenced: 46219
[ 589.387858] EXT4-fs error (device mmcblk0p8): ext4_lookup:1437: inode # 7020: comm node: deleted inode referenced: 46219
[ 604.458268] EXT4-fs error (device mmcblk0p8): ext4_lookup:1437: inode # 7020: comm configure_ediso: deleted inode referenced: 46218
[ 604.698049] EXT4-fs error (device mmcblk0p8): ext4_lookup:1437: inode # 7020: comm configure_ediso: deleted inode referenced: 46218
[ 605.449150] EXT4-fs error (device mmcblk0p8): ext4_lookup:1437: inode # 7020: comm node: deleted inode referenced: 46219
[ 605.454843] EXT4-fs error (device mmcblk0p8): ext4_lookup:1437: inode # 7020: comm node: deleted inode referenced: 46219
I tryed re flashing but they persist. running fsck gives no result
Any idea????
Community Manager
Hello CristianMori,
When did this behavior started? Which flashing method were you using?
In case you haven't tried it, I'd suggest you to try flashing your board using the flashall method. You can find how to use flashall in https://communities.intel.com/docs/DOC-25154 https://communities.intel.com/docs/DOC-25154.
-Peter.
CMori2
Hi Peter
I tried first with the intel application installer, but was not working.
I tried with the flashall, and still not working. Could not find the dfu device.
Then I had to login and stop the boot and force the dfu manually, and at that point I could use the flash all
Even after the flash all, the same problem persisted.
I am going to play with it more tonight. A colleague suggested to remove the edison from the board and plug it back in. I'll keep you posted
Community Manager
In that case I believe your best option would be to submit an email to this form:
https://customercare.intel.com/?lang=en-US
We should be able to help you more accurately there.
-Peter.
CMori2
Thanks Peter.
Curiously enough, against what I was thinking, popping the module out of the baseboard (with no power, of course) and putting it back in solved the issue with no more flashing needed......
I'll keep monitoring and update...
Community Manager
That is very strange. Nevertheless, I'm glad to hear that it is now working fine. If you ever notice any other odd behavior, please post it on the community, we'll try to help you in any way we can.
-Peter.
Community Manager
I got the same error. I use the command 'dd if=/media/sdcard/tmp.img of=/dev/mmcblk0 bs=1M' to backup my system. In source edison, do not show the error, but the backup show as follow.
[ 709.032200] EXT4-fs error (device mmcblk0p8): htree_dirblock_to_tree:920: inode # 34510: block 9226: comm gunicorn: bad entry in directory: directory entry across range - offset=0(0), inode=959658551, rec_len=27680, name_len=111
[ 709.271845] EXT4-fs error (device mmcblk0p8): htree_dirblock_to_tree:920: inode # 34510: block 9226: comm gunicorn: bad entry in directory: directory entry across range - offset=0(0), inode=959658551, rec_len=27680, name_len=111
[ 709.401410] EXT4-fs error (device mmcblk0p8): htree_dirblock_to_tree:920: inode # 34510: block 9226: comm gunicorn: bad entry in directory: directory entry across range - offset=0(0), inode=959658551, rec_len=27680, name_len=111
[ 709.531772] EXT4-fs error (device mmcblk0p8): htree_dirblock_to_tree:920: inode # 34510: block 9226: comm gunicorn: bad entry in directory: directory entry across range - offset=0(0), inode=959658551, rec_len=27680, name_len=111
[ 712.261281] EXT4-fs error (device mmcblk0p8): htree_dirblock_to_tree:920: inode # 34510: block 9226: comm gunicorn: bad entry in directory: directory entry across range - offset=0(0), inode=959658551, rec_len=27680, name_len=111
[ 712.434322] EXT4-fs error (device mmcblk0p8): htree_dirblock_to_tree:920: inode # 34510: block 9226: comm gunicorn: bad entry in directory: directory entry across range - offset=0(0), inode=959658551, rec_len=27680, name_len=111
[ 712.611272] EXT4-fs error (device mmcblk0p8): htree_dirblock_to_tree:920: inode # 34510: block 9226: comm gunicorn: bad entry in directory: directory entry across range - offset=0(0), inode=959658551, rec_len=27680, name_len=111
[ 712.741457] EXT4-fs error (device mmcblk0p8): htree_dirblock_to_tree:920: inode # 34510: block 9226: comm gunicorn: bad entry in directory: directory entry across range - offset=0(0), inode=959658551, rec_len=27680, name_len=111
Community Manager
Hello xd11223,
Have you already tried to reflash and remount the board just like CristianMori? In case you haven't, could you please do and let us know if something changes?
In case the issue persist, do you have access to another expansion board? I would like to check if the issue is related to it.
Let me know.
-Peter.
Community Manager
I already try to use flashall.sh to re-flash the board. After the first post-install.sh, then restart.
After restart, use dd to restore my system. Sometimes there are same error.
This system is which using the create_debian_image.sh created, and follow the flash flow: using the flashall.sh.
Now I create my system by mounting ext4 and chroot, it seems like okay. Thanks.
