Intel® Makers
9872 Discussions
Eclipse/Edison libraries out of sync. // Insufficient space to flash Edison with Yocto 2.1
Community Manager
I am currently trying to run a project on the Edison using the Eclipse IDE. The problem is that when I try to connect to the Edison, I get the following error: (see image below)
I have a more recent version of Eclipse (downloaded 10-16-15) than the version of Yocto (1.7) I have flashed onto the Edison. Believing this was the reason for the error message below, I attempted to flash the Edison with Yocto 2.1. To do this, I followed Intel's instruction manual. However, when I tried dragging the extracted files onto the Edison, it gave me a warning that there was insufficient space on the Edison (about 750MB available but needed about 250MB more).
Unable to connect to the Edison using this version of Eclipse and unable to flash the Edison with the latest image, I am unsure what to do. Is there some way around this error so that I can flash the Edison with Yocto 2.1? Is there some way I should downgrade the Eclipse IDE instead so that the libraries are compatible?
Diego_V_Intel
Hello Ethan_Sterk,
Flashing the latest Yocto image requires to perform a new method which uses the Flash Tool Lite. Please take a look at the following document where there are more details about the Edison's flashing process:
The Flash Tool Lite can be downloaded from this site: https://software.intel.com/en-us/iot/hardware/edison/downloads IoT - Intel® Edison Board Download | Intel® Developer Zone. You will find, under the Flash Tool Lite section, a user's manual too.
Once you have flashed the Yocto image, follow the step-by-step guide to install and use Eclipse. The guide is available in the following site: https://software.intel.com/en-us/eclipse-getting-started-guide IoT - Eclipse* User Guide for C/C++ | Intel® Developer Zone
Diego.
Diego_V_Intel
Hello Ethan_Sterk,
Diego.
Community Manager
Hi Diego,
Thank you for your quick response! This was exactly what I needed to do. The libraries are now synchronized. Thanks again!
Best,
Ethan
