Intel® Makers
9881 Discussions
Eclipse JavaDoc / Source
DRoss4
Hi all, I've managed to setup Eclipse to run and debug my projects on my Edison + Arduino Breakout board using both C++ and Java.
When I import and use UPM classes using C++ I can see the documentation like this:
On the other hand when importing and using classes using Java I see this:
What is the best way to have this info displayed (pointing to Javadoc if present, or attaching source)?
Diego_V_Intel
Hello gnogna82,
There is a Javadoc tool available that generates HTML documentation about a Java program. In order to do so, you must have tags throughout your Java code in order for the Javadoc tool to be able to create the HTML document. I recommend you to take a look at the following site for additional details: https://students.cs.byu.edu/~cs240ta/fall2012/tutorials/javadoctutorial.html Javadoc Tutorial
Diego.
Diego_V_Intel
Hello gnogna82,
Let me check if I'm able to find information about this. If I find anything I'll post it here.
Diego.
Diego_V_Intel
Hello gnogna82,
Diego.
