Hi,this
While trying to send data from my Edison to the Intel Dashboard IoT Cloud, nothing is showing up in the chart data. In the serial console I get this:
2016-04-08T22:48:45.978Z - [32minfo [39m: Trying to connect to host ...
2016-04-08T22:48:46.949Z - [32minfo [39m: Connected to dashboard.us.enableiot.com
2016-04-08T22:48:46.953Z - [32minfo [39m: Environment: prod
2016-04-08T22:48:46.954Z - [32minfo [39m: Build: 0.14.5
2016-04-08T22:48:49.747Z - [32minfo [39m: Device ID set to: 02-00-86-97-7b-16
● iotkit-agent.service - iotkit-agent
Loaded: loaded (/lib/systemd/system/iotkit-agent.service; enabled)
Active: activating (auto-restart) (Result: exit-code) since Fri 2016-04-08 22:48:58 UTC; 1s ago
Process: 1425 ExecStart=/usr/bin/iotkit-agent [1;31m(code=exited, status=1/FAILURE) [0m
Main PID: 1425 (code=exited, status=1/FAILURE)
Active: activating (auto-restart) (Result: exit-code) since Fri 2016-04-08 22:48:58 UTC; 6s ago
[1;32m● [0m iotkit-agent.service - iotkit-agent
Active: [1;32mactive (running) [0m since Fri 2016-04-08 22:49:08 UTC; 1s ago
Main PID: 1436 (node)
CGroup: /system.slice/iotkit-agent.service
└─1436 node /usr/bin/iotkit-agent
Registering components
It looks, that there is a issue with the connection since the status is FAILURE.
I am not sure what could be the reason for this.
Hi Jean,
Which is the result of running the following commands:
uname –a systemclt status iotkit-agent
Did you set a password, name and WiFi connection for the board using configure_edion --setup?
Does the board have Internet connection? Please post a screenshot of running ifconfig and ping www.google.com –c3
Are you following the instructions from: https://software.intel.com/en-us/intel-iot-platforms-getting-started-cloud-analytics https://software.intel.com/en-us/intel-iot-platforms-getting-started-cloud-analytics
Charlie
Hi,Yes I have use the started guide from the cloud, I have set it up, and is connected to the same wifi of my laptop. When I start it for the first time, I could see the data on the Iot, but after I flashed to the latest version I started to experience some errors.. I tried all the codes you mentioned, everything looks fine except the iotkit-agent status which give me the code=existed, status=1/FAILURE
Hi Jeanfranco,
In order to be able to run the service successfully I suggest you to run:
systemctl stop iotkit-agent systemctl disable iotkit-agent reboot systemctl start iotkit-agent systemctl enable iotkit-agent reboot
After this, check the status of the service. If this doesn't work I suggest you to update the service and image you are using, I saw that the image you are using is from Jun 19 2015, the latest one is from Mar 14 2016. [https://software.intel.com/en-us/iot/hardware/edison/downloads https://software.intel.com/en-us/iot/hardware/edison/downloads] Check the output of running uname –a on this image:
Linux jarvis3.0 3.10.17-poky-edison+ # 2 SMP PREEMPT Mon Mar 14 15:26:16 PDT 2016 i686 GNU/Linux
I'm guessing that the service could be old too, run the command opkg list-installed | grep agent, I'm using the 1.7.0–r0 version.
Charlie
Hi Charlie,
I have flashed with the new version, and did the reboot with and without the agent disabled. My issue persist what I found strange is that every time I run the systemclt status iotkit-aget it appears as it is running, but then I do it again it get the FAILURE code, then again the FAILURE, then again is running. Is this normal? I am a little confuse about this every time I run the status it looks like it is changing, I am attaching a picture of it. I am still not able to send data. (Nothing is being show in the IoT CLoud DAshboard)
What does it means : Hint: Some lines were ellipsized, use -l to show in full?
The –l parameter will show more information in the debug message. Please run systemctl status iotkit-agent –l and uname –a (just to verify that the board has indeed the latest image) and show us a screenshot of it. Please use the flashall script to re-flash the board. https://communities.intel.com/docs/DOC-25154 https://communities.intel.com/docs/DOC-25154
You are flashing the board with a fresh image and just checking the status of the service is this right? Or are you changing some other service?
Are you using configure_edison --setup to configure your board?
Charlie
Hi Charlie, here is an image of the two commands you told me to use:
I have not use the setup configuration (I did set up the wifi -edison is connected to the same wifi as my laptop-)I am not changing any services, just re-flashing with a new image. the Yocto 3.0.
Issue persist
I re-flashed my edison and I was able to have the same output you were having. I noticed that this happened to me while the board was being powered by the USB port and having already registered my device in the Dashboard.
I did the following, I powered the board with a power supply, delete the device on the Dashboard and re-flashed the board, then I ran the following commands:
date -s "2016-04-14 17:30:00"
iotkit-admin systemctl stop iotkit-agent iotkit-admin test
iotkit-admin activate xxxxxxxxx
systemctl stop iotkit-agent systemctl start iotkit-agent systemctl disable iotkit-agent systemctl enable iotkit-agent
I hope this works for you, now if I run systemctl status iotkit-agent I get:
After this, I reboot the board and I'm not having the issue anymore
Charlie
Hi Charlie,
I fixed the issue, what I did was removing the device from the cloud analytics and adding it again. Also, I type killall node in the root to kill all background programs that were using the address port and did not let iotkit-agent update. Now it works perfectly.
Thank you for all your feedbacks
Jeanfranco
