Community
cancel
Showing results for
Search instead for
Did you mean:
SHyme
Edison BLE Stuck in "Dual Mode" with bleno
I am using https://github.com/sandeepmistry/bleno bleno to create a simple JavaScript Bluetooth peripheral. My code and steps can be found here: http://shawnhymel.com/703/bluetooth-low-energy-peripherals-with-javascript/ Bluetooth Low Energy Peripherals with JavaScript | Shawn Hymel
I made sure to unblock the radio and kill bluetoothd with
rfkill unblock bluetooth
killall bluetoothd
hciconfig hci0 up
It worked for a while (as you can see in the blog post). Eventually, my phone (Android - Samsung Galaxy S5) started showing the Edison as a "Dual Mode" device, which, according to the Edison documentation, is not possible. When I click on the device now in BLE Scanner, it just says "connecting..." forever. Previously, it would make an immediate connection to the Edison's BLE and offer me the available services and characteristics.
"squishy" is the name for my Edison.
I have tried restarting the Edison, restarting Bluetooth on my phone, and even re-flashing Yocto with no success. I have also tried other BLE scanners and programs. I cannot figure out what happened to the radio (something deeper than the Yocto file system?) to cause it to no longer accept BLE connections. This seems to have happened before to others (such as @danki in https://github.com/sandeepmistry/bleno/issues/131 this GitHub issue).
Here are the specifics of my Bluetooth configuration on the Edison. Please let me know if I can provide any more. Any help is appreciated!
root@squishy:~# rfkill list
0: phy0: wlan
Soft blocked: no
Hard blocked: no
1: brcmfmac-wifi: wlan
Soft blocked: no
Hard blocked: no
2: bcm43xx Bluetooth: bluetooth
Soft blocked: no
Hard blocked: no
3: hci0: bluetooth
Soft blocked: no
Hard blocked: no
root@squishy:~# systemctl status bluetooth -l
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled)
Active: inactive (dead) since Sat 2015-11-28 17:52:28 UTC; 20min ago
Docs: man:bluetoothd(8)
Process: 241 ExecStart=/usr/lib/bluez5/bluetooth/bluetoothd (code=exited, status=0/SUCCESS)
Main PID: 241 (code=exited, status=0/SUCCESS)
Status: "Quitting"
Nov 26 17:39:02 squishy bluetoothd[241]: Bluetooth daemon 5.24
Nov 26 17:39:02 squishy bluetoothd[241]: Starting SDP server
Nov 26 17:39:03 squishy bluetoothd[241]: Bluetooth management interface 1.3 initialized
Nov 26 17:39:03 squishy bluetoothd[241]: Sap driver initialization failed.
Nov 26 17:39:03 squishy bluetoothd[241]: sap-server: Operation not permitted (1)
Nov 26 17:39:03 squishy bluetoothd[241]: hci0 Load Connection Parameters failed: Unknown Command (0x01)
Nov 26 17:39:03 squishy systemd[1]: Started Bluetooth service.
Nov 26 17:39:06 squishy bluetoothd[241]: Endpoint registered: sender=:1.7 path=/MediaEndpoint/A2DPSource
Nov 26 17:39:06 squishy bluetoothd[241]: Endpoint registered: sender=:1.7 path=/MediaEndpoint/A2DPSink
Nov 28 17:52:28 squishy bluetoothd[241]: Terminating
root@squishy:~# bluetoothctl
[NEW] Controller 98:4F:EE:04:3E:F9 BlueZ 5.24 [default]
[CHG] Controller 98:4F:EE:04:3E:F9 Name: squishy
[CHG] Controller 98:4F:EE:04:3E:F9 Alias: squishy
[CHG] Controller 98:4F:EE:04:3E:F9 Class: 0x000110
[CHG] Controller 98:4F:EE:04:3E:F9 UUIDs:
00001200-0000-1000-8000-00805f9b34fb
00001800-0000-1000-8000-00805f9b34fb
00001801-0000-1000-8000-00805f9b34fb
0000110e-0000-1000-8000-00805f9b34fb
0000110c-0000-1000-8000-00805f9b34fb
0000111e-0000-1000-8000-00805f9b34fb
0000110a-0000-1000-8000-00805f9b34fb
0000110b-0000-1000-8000-00805f9b34fb
[CHG] Controller 98:4F:EE:04:3E:F9 Alias: BlueZ 5.24
[CHG] Controller 98:4F:EE:04:3E:F9 Class: 0x200110
[CHG] Controller 98:4F:EE:04:3E:F9 Class: 0x280110
[CHG] Controller 98:4F:EE:04:3E:F9 Class: 0x2c0110
[bluetooth]# show
Alias: squishy
Class: 0x2c0110
Powered: yes
Discoverable: no
Pairable: yes
UUID: PnP Information (00001200-0000-1000-8000-00805f9b34fb)
UUID: Generic Access Profile (00001800-0000-1000-8000-00805f9b34fb)
UUID: Generic Attribute Profile (00001801-0000-1000-8000-00805f9b34fb)
UUID: ...
MCara4
New Contributor III
Hi ShawnHymel,
probably you are using bleno version 0.3.2, this version had a serious problem on Yocto. Luckily two days ago was fixed by version 0.3.3, see:
https://github.com/sandeepmistry/bleno/commit/0c150480320f23bc04ea1618670712a4e9c55f91 - add isYocto check for skipping first set of adv and sr data (# 151) · sandeepmistry/bleno@0c15048 · GitHub
Please let me know if this solve your problem.
-max
SHyme
Thanks, max! I grabbed the latest repo from github, unzipped it, and ran npm install inside the directory. For some reason, the installation process can't find libudev headers. I see that libudev should be installed, but it seems that I need libudev-dev to get the headers, and that is not in any of the opkg.net Edison repos (e.g. http://repo.opkg.net/edison/repo/core2-32/ Index of /edison/repo/core2-32). I'm not even sure how it worked at all in the first place if bleno needs libudev.h.
root@squishy:~/bleno-master# npm install
npm WARN optional dep failed, continuing xpc-connection@0.1.4
npm WARN engine node-hid@0.5.1: wanted: {"node":">=4.0.0"} (current: {"node":"0.10.38","npm":"1.4.28"})
> node-hid@0.5.1 install /home/root/bleno-master/node_modules/node-blink1/node_modules/node-hid
> node-pre-gyp install --fallback-to-build
make: Entering directory '/home/root/bleno-master/node_modules/node-blink1/node_modules/node-hid/build'
CC(target) Release/obj.target/hidapi/hidapi/libusb/hid.o
../hidapi/libusb/hid.c:47:20: fatal error: libusb.h: No such file or directory
# include
compilation terminated.
hidapi.target.mk:84: recipe for target 'Release/obj.target/hidapi/hidapi/libusb/hid.o' failed
make: *** [Release/obj.target/hidapi/hidapi/libusb/hid.o] Error 1
make: Leaving directory '/home/root/bleno-master/node_modules/node-blink1/node_modules/node-hid/build'
gyp ERR! build error
gyp ERR! stack Error: `make` failed with exit code: 2
gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:267:23)
gyp ERR! stack at ChildProcess.emit (events.js:98:17)
gyp ERR! stack at Process.ChildProcess._handle.onexit (child_process.js:820:12)
gyp ERR! System Linux 3.10.17-poky-edison+
gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/home/root/bleno-master/node_modules/node-blink1/node_modules/node-hid/build/HID/v0.5.1/Release/node-v11-linux-ia32/HID.node" "--module_name=HID" "--module_path=/home/root/bleno-master/node_modules/node-blink1/node_modules/node-hid/build/HID/v0.5.1/Release/node-v11-linux-ia32"
gyp ERR! cwd /home/root/bleno-master/node_modules/node-blink1/node_modules/node-hid
gyp ERR! node -v v0.10.38
gyp ERR! node-gyp -v v1.0.1
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/home/root/bleno-master/node_modules/node-blink1/node_modules/node-hid/build/HID/v0.5.1/Release/node-v11-linux-ia32/HID.node --module_name=HID --module_path=/home/root/bleno-master/node_modules/node-blink1/node_modules/node-hid/build/HID/v0.5.1/Release/node-v11-linux-ia32' (1)
node-pre-gyp ERR! stack at ChildProcess. (/home/root/bleno-master/node_modules/node-blink1/node_modules/node-hid/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
node-pre-gyp ERR! stack at ChildProcess.emit (events.js:98:17)
node-pre-gyp ERR! stack at maybeClose (child_process.js:766:16)
node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (child_process.js:833:5)
node-pre-gyp ERR! System Linux 3.10.17-poky-edison+
node-pre-gyp ERR! command "node" "/home/root/bleno-master/node_modules/node-blink1/node_modules/node-hid/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
node-pre-gyp ERR! cwd /home/root/bleno-master/node_modules/node-blink1/node_modules/node-hid
node-pre-gyp ERR! node -v v0.10.38
node-pre-gyp ERR! node-pre-gyp -v v0.6.12
node-pre-gyp ERR! not ok
npm ERR! node-hid@0.5.1 install: `node-pre-gyp install --fallback-to-build`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the node-hid@0.5.1 install script.
npm ERR! This is most likely a problem with the node-hid package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR! node-pre-gyp install --fallback-to-build
npm ERR! You can get their info via:
npm ERR! npm owner ls node-hid
npm ERR! There is likely additional logging output above.
npm ERR! System Linux 3.10.17-poky-edison+
npm ERR! command "node" "/usr/bin/npm" "install"
npm ERR! cwd /home/root/bleno-master
npm ERR! node -v v0.10.38
npm ERR! npm -v 1.4.28
npm ERR! code ELIFECYCLE
npm ERR! not ok code 0
SHyme
Wrong install output. I was able to install libusb with
opkg install libusb-1.0-dev
However, now I am getting the real error with the missing libudev.h file:
Silly forums are not letting me paste in the whole text, so here's a gist of the output: https://gist.github.com/ShawnHymel/804620ceeed764638d41 npm install bleno output · GitHub
MCara4
New Contributor III
Hi ShawnHymel,
I usually install bleno from npm repo without download it from github and it works. Did you tried this way?
SHyme
I have, and it still does not work. From what I can tell, the npmjs package (https://www.npmjs.com/package/bleno bleno) does not contain the Yocto fix that was pushed to GitHub 3 days ago.
MCara4
New Contributor III
In this case you can use the version from NPM and change only the file that has the bug, ie: gap.js in /home/root/.node_app_slot/node_modules/bleno/lib/hci-socket/
SHyme
That didn't stop the other errors, but resetting the phone also seemed to put the Edison back as being listed as "BLE only" (instead of just turning the BLE radio off and on). I really wish there was a way to easily replicate this and see why Android fails at BLE.
