Community
cancel
Showing results for
Search instead for
Did you mean:
IForu1
Honored Contributor I
Edison Board Not Being Detected in Intel XDK and Cannot connect Edison Board Through SSH Connect
Jump to solution
Hi,I am a really new guy in My Edison seems to be cannot connected to XDK.
I use Ubantu linux system and edison board,and i can use the cloud service now as the guide,but when i try to use intel XDK, it cannot detected my device,even i try to add a device manually,
use
IP Address: <192.168.2.15>
Port: 58888
and runmailto:root@edison root@edison
mailto:root@edison root@edison:~# systemctl enable xdk-daemon
mailto:root@edison root@edison:~# systemctl restart xdk-daemon
whitelist --add
still get Error: connect ETIMEDOUT,then i changed the ssh port to 5888,it still show connect refused,i donnot what wrong with my board?
Any help would be greatly appreciated!(pass: i can run arduino sample well,it can connect to my board and upload example Blink to my board and run well,but i need to use javascript)
those are the information about my configure and test
connect to wifi seems ok, but try from computer ssh connect to board failed,whatever ues 192.168.2.15 or 10.20.215.86,ping also failed
IForu1
problem solved
Bo L.
IForu1
problem solved
Bo L.
KAaro
What solved the problem? I am having a similar issue and everything other boards have suggested are not helping.
MGudi
How did you solve the problem?
