Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
New Contributor II
Edison Breakout Board Hardware Guide Help
Jump to solution
I received my Intel Edison Breakout Board Kit Model EDI1BB.AL.K today. I went to this page to get the information on the connectors and and so on.
/docs/DOC-23252 https://communities.intel.com/docs/DOC-23252
I don't want to get off on the wrong foot here being new and all, but that has to be the worst pdf document for a board I have ever seen.
Here are just a few reason why.
# 1) It shows a DC with center pin jack "J22" which there clearly isn't one.
# 2) There is no J22 on the board anywhere but its shown on page 9
# 3) micro USB J3, is not even mentioned in the document. So what is it for ?
# 4) micro USB J16 is talked about on in section 2.2, but is far to vague of an explanation.
# 5) J21 is shown on page 9 figure 2, but does not even talk about it or what its purpose is.
# 6) J2 is not shown or talked about.
# 7) J1 is not shown or talked about.
These are just a few but serious issues with this document.
How does Intel expect anyone to make use of this with this kind of document ?
Now, If i have missed some other document that explains this board better then i apologize Intel, and if there is one then dump this .pdf and just keep the better one.
Tags (1)
Accepted Solutions
Highlighted
Re: Edison Breakout Board Hardware Guide Help
Jump to solution
There is a newer version of this document with fixes that has been in the works. I will check in on progress and get an update pushed to the community. Thanks for the feedback!
Highlighted
1 View
Jump to solution
Highlighted
Jump to solution
I have Revision 002 of this document and still find no mention of J3-microUSB connector. Is there a later version available?
Highlighted
Valued Contributor I
Jump to solution
Version 4 is available here:
Highlighted
Jump to solution
Great... thank you!
