Intel® Makers
Intel® Edison, Intel® Joule™, Intel® Curie™, Intel® Galileo
Welcome - This is a Peer-to-Peer Forum only. Intel has discontinued these products but you may find support from other customers on this Forum
9868 Discussions
Edison DNS problem
BTura1
My Edison can ping IP addresses but not domains. It doesn't seem to resolve DNS or DNS server defined?
I wonder if there is a additional step to set up dns server or should I expect to edison get it automatically from DHCP?
MMich22
New Contributor II
For some reason my Edison does get a wrong IP from my dhcp server. I do not know yet where the problem is. What may help you is to change the nameserver to 8.8.4.4
Therefore change the nameserver in /etc/resolv.conf. This should help you.
MMich22
New Contributor II
BTura1
thanks, are you getting NameServer record from your DHCP automatically?
MMich22
New Contributor II
No. For some reason my edison also gets the wrong IP address. It uses always 192.168.2.X. I do not know yet why this happens. For now I'm using static settings for wlan0.
TKanw
Going to throw out another possible issue I've seen recently:
If your system partition is full, resolv.conf will be corrupted and DNS resolution will fail. The solution here is, of course, to clear out some space in the system partition. In my particular case, this was the no-limit journal logging issue describe here:
https://software.intel.com/en-us/blogs/2014/11/18/intel-edison-troubleshooting-and-faq Troubleshooting Intel® Edison and Intel® Galileo | Intel® Developer Zone
