Intel® Makers
9873 Discussions
Edison Driver does't come out but it exist as USB download gadget
TGoh1
When i try to start on development on edison board but i face the problem that when edison board is connected to my computer it does't come out anything but it show edison board as USB download gadget. What can i do to solve the problem?? i already tried out everything i can do. I stack at here for a week and i had tried to reinstall the driver.
Carlos_M_Intel
Hi mrgterence,
Are you trying with https://software.intel.com/en-us/iot/hardware/edison/downloads the Integrated Installer?
Could you also attach a screenshot of what you get in the Device Manager > Ports
Have you tried to/docs/DOC-25154 run the flashall script?
Have you tried to use other cables?
Charlie
Carlos_M_Intel
Hi mrgterence,
Charlie
TGoh1
Thanks for reply~ I finally saw the Edison driver after flash manually through intel phone flash lite but it is normal for the driver to be empty?
Carlos_M_Intel
Hi mrgterence,
What do you exactly means when you said that the driver is empty? Could you attach a screenshot of this that shows that the driver is empty?
Charlie
