Community
cancel
Showing results for
Search instead for
Did you mean:
KMitc3
Edison Eclipse C++ Regex does not exist
I'm attempting to use regex_replace in my program, but when I try to do it the standard C++ way, I get errors.
I have 'using namespace std;' at the top of my file, and my code I'm trying to compile is:
//returns the output of the battery-voltage command on the edison, something like "Battery Voltage = 4010 mV\nBattery level = 68%"
std::string battery = getCmdOutput("battery-voltage");
//regex is suppose to filer out everything except the mV reading in the first line
std::regex batmVReg("(Battery\ Voltage\ =\ )|(\ mV)");
int batmV = std::regex_replace(battery, batmVReg, "\n");
It's telling me that "'regex' is not a member of std" and "function 'regex_replace' could not be resolved". Is there a different way to go about doing regex in Eclispe For Edison?
KMitc3
I just enabled c++11, since I realized I needed it for other parts of my project, but the regex still isn't working.
Carlos_M_Intel
Hi Keith,
How did you enable C++ 11? Did you add the flags under the G++ compiler?
Did you use this https://software.intel.com/en-us/eclipse-for-iot-troubleshooting-and-faq# How_to_set_C++11 IoT - Eclipse* for Intel® IoT Platforms Troubleshooting and FAQ | Intel® Developer Zone?
Also, which Eclipse version are you using?
Could you post the full error you are getting?
Charlie
KMitc3
Hi Charlie,
Yes I have enabled C++11 as shown in the link you posted, but I'm not sure that it is actually working.
I found a way around using the regex, but now I'm trying to use threading and it's saying "std::thread could not be resolved". I'm using the latest Eclipse version from the download page "Luna SR2 (4.4.2)", the error Eclipse is throwning is "std::regex could not be resolved"
Carlos_M_Intel
Hi Keith,
You said that you found a way around using the regex, but you also said that you are having the error message "std::regex could not be resolved" . Are you having problems with regex or is only with thread?
Charlie
KMitc3
Hi Charlie,
Sorry, I realize I worded that strangely.
I found a way around using regex that I'm using until I can resolve this issue. The error that Eclipse is giving me when I try to use regex is "std::regex could not be resolved".
I've followed the part of the FAQ on how to enable c++11, but I believe it isn't working because when I try to use things like threading, it also tells me that std::thread can't be resolved.
I hope thats a bit clearer
Carlos_M_Intel
Hi Keith,
Which # includes are you using?
# include
# include
Also, select your code.cpp in Eclipse. Then right click on it > Properties > C/C++ Build > Settings and add on "Command:" -std=c++11
Let me know if you get improvements with this.
Kind regards,
Charlie
Carlos_M_Intel
Hi Keith,
Do you have updates on this?
Have you been able to use regex and C++11 on Eclipse?
Charlie
KMitc3
CMata_Intel wrote:
Hi Keith,
Charlie
So sorry, I totally forgot to reply!
I tried the string and regex includes, as well as adding "Command:" -std=c++11 to my code file's build settings, but none of it fixed the issue, it still says that they are not resolved.
Matthias_H_Intel
possibly only an IDE but not a compiler issue? Does it compile (despite IDE messages)?
which Eclipse version do you use?
KMitc3
It won't compile normally, but if I force it to compile despite the errors, it just skips that part of the code when running
Carlos_M_Intel
Hi Keith,
On Eclipse Luna SR2 (4.4.2) and following the steps from https://software.intel.com/en-us/eclipse-for-iot-troubleshooting-and-faq# How_to_set_C++11 IoT - Eclipse* for Intel® IoT Platforms Troubleshooting and FAQ | Intel® Developer Zone I do not have problems with the code:
# include
# include
# include
int main()
//std::string battery = getCmdOutput("battery-voltage");
//int batmV = std::regex_replace(battery, batmVReg, "\n");
On step 5, check that you have the following selections:
Charlie
Carlos_M_Intel
Hi Keith,
Do you have updates on this? Have you been able to compile and run the code?
Charlie
