Intel® Makers
9881 Discussions
Edison Flash tool invisible on mac Yosemite
DDirk
After reporting some strange behaviour of my Edison, I got the advise to try to re-flash it. So I downloaded and installed the Flash tool for mac It was a file called 'PhoneFlashToolLite_5.2.4.22_mac64.pkg'.
I double-clicked on it and an install procedure started, and the process looked well.
However, after the (successful) procedure, I cannot find the Flash Tool anywhere. Not in the Applications folders, not elsewhere I looked. The procedure gave the option to specify the location of the installation, but the only two available options where 'Macintosh HD' or 'Edison'. I could not specify the path.
I installed it a second time, same result.
Since the install procedure reported to have been successful, I think it is there somewhere. Does anyone know what is the path and file name where the Flash Tool could be? If I at least have the correct name, I could try to find it with the 'find -name' command.
Thanks in advance,
Dirk.
Pedro_M_Intel
Hello Dirk1969,
I just installed Flash Tool Lite on my Mac (also on Yosemite) and I was able to find the tool in the following path:
/Applications/Phone Flash Tool Lite.app
Once you are there, go to:
/Applications/Phone Flash Tool Lite.app/contents/MacOS
And type:
sudo ./phoneflashtoollite
The tool should open normally.
Peter.
Pedro_M_Intel
Hello Dirk1969,
And type:
Peter.
DDirk
Thanks! I could find indeed the Flash Tool on the path you mentioned.
