Intel® Makers
9868 Discussions
Edison Gattlib
MMoha16
Hello all ,
I have read about the Gattlib library which enables communication over bluetooth which can be installed on the edison and run python scripts which must import from the gattlib
Has anyone succeeded in working with this library because i am getting an error "fatal error: boost/python/list.hpp: No such file or directory" when i run to install it via the "pip install gattlib"command on the edison
Pedro_M_Intel
Hello Massem,
gattlib can be installed with pip as you can see in https://bitbucket.org/OscarAcena/pygattlib OscarAcena / pygattlib — Bitbucket. In case you don't have pip installed, you can get it with http://alextgalileo.altervista.org/edison-package-repo-configuration-instructions.html AlexT's repo.
Nevertheless gattlib will require that you install gatttool and boost. You can find a guide on how to install gatttool in https://software.intel.com/en-us/articles/using-the-generic-attribute-profile-gatt-in-bluetooth-low-... IoT - Using the Generic Attribute Profile (GATT) in Bluetooth* Low Energy with your Intel® Edison Board and a guide on how to install boost in http://www.boost.org/doc/libs/1_60_0/more/getting_started/unix-variants.html Boost Getting Started on Unix Variants - 1.60.0.
Peter.
Pedro_M_Intel
Hello Massem,
Peter.
MMoha16
Thank you for ur reply , So after downloading boost what should its path be on the edison ?
Pedro_M_Intel
I can see that you recently opened . Do you still need help with boost?
Peter.
MMoha16
No thank you so much . Boost is now installed.
