Intel® Makers
9881 Discussions
Edison Hardware Watchdog
RHeat
I am not entirely clear that Edison has a hardware watchdog in the SOC. There is sample software watchdog code (/usr/bin/watchdog-sample), and there is a /dev/watchdog present
Can someone point me to data sheet on the SOC hw watchdog?
Can someone point to code using this? Is the standard linux watchdog (8) utility sufficient to utilize the (presumably ) hardware watchdog found in /dev/watchdog?
I have see prior threads on this but which do not provide the answers to this:
Thanks in advance.
Community Manager
Hi RichH,
Let us investigate further on your questions. We'll contact you as soon as we have an update.
Thank you for your patience.
-Sergio A
Community Manager
Hi RichH,
Thank you for your patience. We've investigated about your case and found out that the Edison does not have general purpose watchdog timers. Additional to this,we also received an alternative option for you. The option would be to use an external watchdog component and connect into the SoC GPIO and PMIC reset signals for monitoring of events.
Please let us know if this is useful and if there's anything else we can do to assist you.
-Sergio A
