Intel® Makers
9880 Discussions
[Edison] IoTK activation issue
rfenj
I tried to use IoT Analytics but I am facing an Activation Issue. In the IoT analytics website, my device is active. But when I tried to register a component, my device is logging that it is not activated. please see below the command and log I got in the terminal.
Could you please tell how I can resolve this ?
rfenj
Ideleted my device in the IoT dashboard and I re did the whole activation flow. After a new activation of the device I restart the Iotkit agent. But this is failing... So it may explain why I was not able to register a component previously.
Does anybody can help me to know why the iotkit-agent can not start properly ? Traces are not really very understandable to me.
Sergio_A_Intel
What version are you using, you can check your version with iotkit-admin –V.
You can also try to stop and start the agent with:
systemctl stop iotkit-agent
systemctl start iotkit-agent
Also what image are you using on your Edison, check the version with configure_edison –version.
Take a look at https://software.intel.com/en-us/intel-iot-platforms-getting-started-cloud-analytics Intel® IoT Platforms: Getting Started: Cloud Analytics | Intel® Developer Zone and follow the steps. Let us know what step you failed to complete.
Sergio
Carlos_M_Intel
Hi redafenj
Have you been able to use your board with the Dashboard? Did you try with the suggestions above?
Charlie
rfenj
Hi
Thanks for your support, I just updated my iotkit version and rename my device and it is working fine.
Reda
