Community
cancel
Showing results for
Search instead for
Did you mean:
YYANG40
Edison Oscillator and timer
I am doing a project, which will use timer in Edison.
Does Edison only have the TSC deadline timer? I can only find this one.
And Is anyone have some documents about oscillator in both Edison compute module and Edison Breakout Board? I can not find these in the Hardware guides.
Pablo_M_Intel
Hi Young_23,
We have provided most available information in your other thread /thread/98327 https://communities.intel.com/thread/98327. However, you can still take a look at the http://download.intel.com/support/edison/sb/edisonmodule_hg_331189004.pdf Edison Compute Module Hardware Guide (which according to your description you might already checked before) and check sections 4.1 to see the available clocks of the module. All available features of the clocks are mentioned in that section. I am afraid this is all the information available, but we'll investigate this further. We'll get back to you soon.
Pablo
YYANG40
Hi @PabloM_Intel
Do you know the model number of Quark on edison? Is it Quark D1000, Quark x1000 or else?
Can I access the general purpose timer of Quark? Does the timer of Quark have a pinout?
Thank you very much
Pablo_M_Intel
Hi Young_23,
The information provided in the Edison Compute Module Hardware Guide (http://download.intel.com/support/edison/sb/edisonmodule_hg_331189004.pdf http://download.intel.com/support/edison/sb/edisonmodule_hg_331189004.pdf) is the only information available, there is no other document. Regarding your other question, the MCU on the Edison is a Minute IA CPU.
Pablo
