I am trying to output a pwm from an intel edison to drive a small test chip. I have been able to do this. I was wondering if it is possible (or how) to store the output of my test chip on edison or to an SD card so that I can do some analysis on the data collected from the chipr. The chip will be running for a few minutes.
I appreciate your suggestions.
Thank you,
Efrem
Hi hin123,
That's possible. You could store the data on the SD card and then analyze it properly. However, the detail here is how your chip provides the data, what interface does it use? If I understood you well, you use the PWM signal to control the chip, however how would the chip send the information to the Edison?
Can you post the model of the chip so I can check its datasheet?
Diego
Hi hin123,
Do you still need help on this?
Diego
