Intel® Makers
9867 Discussions
Edison Power Mode when MCU puts Host to sleep
Clifford_K_Intel
I am creating a wireless sensor network to collect data using the Edison MCU as a data sink with the objective of lowest power consumption. When the data is read from the UART the MCU wakes up the host using the host_send API and passes the data.
I am aware there are 3 power modes available on the Edison.
My question is when the MCU is running and the mcu_sleep command give to put the host asleepm , What power mode is the host?
Cliff
Community Manager
Hello, Cliff
Thank you for contacting Intel Customer Support.
Check the link below and let me know if it's helpful for you:
https://software.intel.com/en-us/node/557354# Waking_up_the_host_CPU_using_the_MCU
Alexandra
Clifford_K_Intel
Hi Alexandra,
Thanks for the reply but no this isn't helpful. I need to understand what state the CPU is set when using the sleep MCU API.
So when i tell the host to sleep and wake it up using
mcu_sleep(12000); /* wake up CPU every 2 minutes */
host_send((unsigned char*)"wake up!\n", 10);
What below states will the host CPU be when sleeping?
"mem" > /sys/power/state
"freeze" > /sys/power/state
Cliff
Community Manager
Hi, Cliff
The CPU can be in either "mem" or "freeze" states, but ideally it will be in "mem" for significant power saving.
The following line of code "mcu_sleep(1200)" only sets the MCU to sleep, not the Edison entirely.
More information on the Intel Edison power states can be found in the following documentation: https://github.com/01org/edison-linux/blob/master/Documentation/power/states.txt https://github.com/01org/edison-linux/blob/master/Documentation/power/states.txt
Alexandra
