Community
cancel
Showing results for
Search instead for
Did you mean:
MingHan_N_Intel
Edison WiFi test software for FCC/IC EMC certification
We've built a gateway using the Intel Edison module and we'll be launching it end of this month. Before that though, our gateway will have to go thru FCC/IC EMC certification for WiFi which is scheduled for March 21st. Can Intel provide us with the software utility that Intel used when going thru the same certification? We are hoping that the software utility can set Edison WiFi to continuous transmit and also to set TX power level and hop frequency.
Thanks in advance.
-Niam
Community Manager
Hello Niam,
Thanks for reaching out!
Unfortunately, we are not able to provide you with the tools used by Intel during the FCC/IC EMC certification process on Edison, as Intel does not provide the certification guide or tools. We suggest you to consult with a local certification vendor in case you need any help with the certification process.
Pedro M.
