Intel® Makers
9882 Discussions
Edison Wifi reconfiguration, python problem
RCopp
question, I tried to switch the intel edison to a new wifi network, after having it setup for another one (new ip adress)
again used configure_edison --wifi for this, All seems to be fine, ifconfig shows also the new network
however now this line in a python script hangs
host = socket.gethostbyname(socket.gethostname())
when i configure the network back to the old one, all is fine again...
a reboot also is not helping...
any idea?
Sergio_A_Intel
What image are you using? What is the output of configure_edison –version?
What is the output of /etc/wpa_supplicant/wpa_supplicant.conf?
Do you have any additional errors? Have you tried with configure_edison –setup?
Sergio
