Intel® Makers
9881 Discussions
Edison and the Arduino Breakout Board Drivers
EH1
They're missing. No amount of google has helped
All of the links that I find are very similar to this https://software.intel.com/en-us/installing-drivers-for-intel-edison-board-with-windows IoT in that they all direct you to https://software.intel.com/en-us/iot/hardware/edison/downloads https://software.intel.com/en-us/iot/hardware/edison/downloads and the links there all direct me to a 404 page.
Have they moved?
TIA
Update: I managed to find the Edison Board Configuration Tool, but attempting to install fails with "Integrity Checking Failed" claiming the source file is incorrect.
Community Manager
Hi PDXErik,
Thank you for reporting this issue. We're aware of it and it has been reported last week. Actually, I've just followed up with the proper team so the site can be fixed as soon as possible.
We apologize for any inconvenience this may cause to you.
Have a nice day.
Diego V.
ctayl2
Someone fix the page please..
Community Manager
Hi all,
After following up with the proper team, they confirmed me that the Edison's Yocto image and all other binary files were moved to the Download Center so all downloads would be in a single location. They also confirmed me that this is a work in progress and some links are down, however they will be redirected to a pre-populated Download Center search query soon.
Meanwhile, the current Yocto image and source can be accessed through the following link: https://downloadcenter.intel.com/download/26995/Intel-Edison-Yocto-Poky-image https://downloadcenter.intel.com/download/26995/Intel-Edison-Yocto-Poky-image
Hopefully all links will be fixed soon.
Diego V.
BMurp5
I have the same problem but I have rung Element14 and asked for technical support. I will let you know if I have any luck. I'm trying to setup the http://nz.element14.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&langId=64&urlReques... Edison Board for Arduino with Arduino Sketch, Linux, Wi-Fi & Bluetooth. The main thrust of my endeavor is to get the Edison configured for the Pixhawk 2.1 Cube.
ctayl2
Yes, I have Pixhawk2.1 as well waiting to be configured to edison and like you, i need to practice this all the setup to Edison-Arduino expansion board then I go back to my Pixhawk. I spent many hours try to figure it out couldn't get to install the driver (error: source file is incorrect) to edison so I could play the arduino sketch. But I was able to flash yocto img from intel, ubilinux and then the latest jubilinux using manual by command "flashall" and did the ssh playing just to see how it goes. And that's all I can get.
Now Edison is now discontinued product of Intel, I'm still hoping that at least they do something about this issue.
-Cecil
