my edison always autoboots and the edison drive don't show on my computer right now. And because the autoboot I also cannot resetup the Intel Edison setup software and flash the image. What can I do to fix this problem? Below is what is shown in PUTTY whenever I open it.
PSH KERNEL VERSION: b0182b2b
WR: 20104000
SCU IPC: 0x800000d0 0xfffce92c
PSH miaHOB version: TNG.B0.VVBD.0000000c
microkernel built 11:24:08 Feb 5 2015
******* PSH loader *******
PCM page cache size = 192 KB
Cache Constraint = 0 Pages
Arming IPC driver ..
Adding page store pool ..
PagestoreAddr(IMR Start Address) = 0x04899000
pageStoreSize(IMR Size) = 0x00080000
*** Ready to receive application ***
U-Boot 2014.04 (Jun 19 2015 - 12:05:55)
Watchdog enabled
DRAM: 980.6 MiB
MMC: tangier_sdhci: 0
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 0
thank you,
Yicheng
Hello wych,
This behavior happens because of the power supply issue that you described in your other thread: . The Edison re-starts the booting process automatically because it is not powered properly. The power supply issue must be resolved first before the Edison can boot successfully.
Please continue the support in the other thread: .
Diego.
Hello wych,
Diego.
