Intel® Makers
9881 Discussions
Edison board config tool: "Unable to download install" when running ./install_GUI.sh
AG5
I'm getting the following error when running the install_GUI.sh script:
Unable to download install configuration("http://communities.intel.com/ https://downloadmirror.intel.com/25871/eng/iot_data.xml"). Please сheck your proxy settings and correct them if needed.
I have a Verizon FIOS internet connection, which is working (ie. I'm able to post this question).
Is the url http://communities.intel.com/ https://downloadmirror.intel.com/25871/eng/iot_data.xml still valid?
AG5
After pressing the Re-try button a few times, I guess the download succeeds.
AG5
BBrau1
hello!
I am having the same issue. I tried keep pressing the Re-check button but it is not working for me. Any other suggestions?
JKowa7
bumping this
I'm getting the same error on a fresh install of xubuntu.
I thought that it might be because of my location(Belgium) so i tried a proxy in the US but that didn't work either.
I copied and pasted the link in a browser (https://downloadmirror.intel.com/25871/eng/iot_data.xml https://downloadmirror.intel.com/25871/eng/iot_data.xml) but it returns a 404.
Maybe I need some permission to let the installer connect to the internet?
Any help would be appreciated !
ADev2
Same problem, it also 404s for me.
If anyone could provide a workaround that would be nice.
JPaulo22
Same problem here, anyone solved it?
