Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Edison capabilities inquiry.
From a review of the hardware guide, and otherwise given the fact that the on-board DDR ram appears to be integrated into the SoC, am I correct in understanding that there is no direct means to access the on-board ram without the use of translation/transmission through a standard protocol channel? If so, does the SoC have any otherwise 'unmentioned' capability (i.e. a memory controller) to directly address/manage additional/external DDR chips? For my particular application I am considering a situation, as in motion-vision-response, in-conjunction with a FPGA or similar which for best results, once the 'processing' was completed, allow such an external IC to proceed as close in step with the processor as possible without the additional lag time of having to 'off-load' the memory contents which is otherwise constrained by the bus speed and number of channels available.
Tags (1)
Highlighted
1 View
Re: Edison capabilities inquiry.
Hi abalducci,
We will investigate to give you a more accurate response.
JPMontero_Intel
Highlighted
1 View
Dear JP,
Thanks, I would appreciate it. I really like both the small form factor and overall design of the Edison and realize this might not be the sort of project it was targeted for, I've long been an Intel fan, but I am trying to decide between having the x86 functionality, or, possibly, the facility of 'true-embedded' where you have access to all functionality on the processor. I suppose I could use a second IC for the purposes of handling external RAM management, but then things start to get a bit redundant.
Highlighted
1 View
Hi abalducci,
We are in the process of making more documentation public in regards to Edison and its SoC, please be patient.
JPMontero_Intel
