Community
cancel
Showing results for
Search instead for
Did you mean:
RHett
Edison doesn't flash & drive isn't showing up
Jump to solution
Today when I tried to "opkg update" I got the message that dev/root is 100% filled, so thought of flashing the device. As the Edison drive didn't show on my computer I decided to use flash tool lite.
But it Fails.
10/01/15 22:25:23.684 ERROR : [Port 0/1/2] Command `"C:\Program Files (x86)\Intel\Phone Flash Tool Lite\dfu-util.exe" "--alt" "u-boot0" "-D" "C:\Users\ramit\Downloads\edison-image-ww25.5-15\u-boot-edison.bin" "-t" "4096" "-d" "8087:0a99"` failed
10/01/15 22:25:23.684 ERROR : [Port 0/1/2] Flash failed (Command type: DFU)
This is what I can see in the terminal. Btw this is my device manager window
Please help me I was making an Instructable about a game (http:// http://http://inteledison.xyz/ inteledison.xyz )I made for the Edison. But now I cannot do anything
RHett
OWWWWW YEAAHHHH I found the solution finally looking around the web Thank you Intel!
I'll share my answer so that after sometime someone who views this page will be able to solve their problem too.
Step 1
We need to download a couple of things. 1. The latest intel Edison image
2. a tool called dfu-util.exe (Device Firmware Upgrade Utilities) & http://dfu-util.sourceforge.net/releases/dfu-util-0.8-binaries/win32-mingw32/libusb-1.0.dll libusb-1.0.dll
you can find these 2 here (http://dfu-util.sourceforge.net/releases/dfu-util-0.8-binaries/win32-mingw32/ http://dfu-util.sourceforge.net/releases/dfu-util-0.8-binaries/win32-mingw32/)
Step 2
unzip the latest intel Edison image. then copy the two files dfu-util.exe & http://dfu-util.sourceforge.net/releases/dfu-util-0.8-binaries/win32-mingw32/libusb-1.0.dll libusb-1.0.dll .
Step 3
see the COM port through device manager and connect to it through putty (in this way we're viewing what's happening inside the Edison)
Step 4
restart the Edison
Step 5
interrupt the boot by pressing Ctrl-C
Step 6- enter the command run do_flash - this puts the Edison in flash mode ready to talk to flashall. (let's see what's flashall in step 7)
Step 7 - Open the exe called flashall.exe(located inside the unzipped folder)
Step 8
see what's happening in the command prompt windows (one opened in putty and the flashall.exe one)
Step 9
it should be working now.
I personally had a issue where the flashall.exe displayed "Device has DFU interface, but has no DFU functional descriptor"
so it was occurred due to a driver problem so I had to install http://downloadmirror.intel.com/24909/eng/IntelEdisonDriverSetup1.2.1.exe Windows Standalone Driver 1.2.1 (can be found here https://software.intel.com/en-us/iot/hardware/edison/downloads https://software.intel.com/en-us/iot/hardware/edison/downloads )
Phew. I'm happy that my Edison is working again
Reference :
http://www.instructables.com/id/Fix-an-Intel-Edison-with-a-Corrupted-Linux-Image/?ALLSTEPS http://www.instructables.com/id/Fix-an-Intel-Edison-with-a-Corrupted-Linux-Image/?ALLSTEPS
https://communities.intel.com/message/280614# 280614 https://communities.intel.com/message/280614
https://communities.intel.com/thread/56012 https://communities.intel.com/thread/56012
https://communities.intel.com/message/311395# 311395 https://communities.intel.com/message/311395# 311395
Post here if you have trouble too....
RHett
Step 1
Step 2
Step 3
Step 4
restart the Edison
Step 5
Step 8
Step 9
Reference :
SJeon14
I'm happy too!! Thank you!!!
RHett
