Community
cancel
Showing results for
Search instead for
Did you mean:
ARash1
Edison gattlib ble
Jump to solution
Hi, i am a beginner to Intel Edison and i have some questions, i am using python scripts on Edison (pygattlib) and i need to communicate with Bluetooth module(Beacon HM-11) and i need help concerning some points:
-i just want to understand the methods used in (write.py) and (read.py)
-what are the handles passed by the method used for? write_by_handle(***?) , read_by_handle(***?)
-i just want to do a simple tic-toc communication with the beacon, just sending any data and receiving the response.
Thanks in advance.
Community Manager
Hello AhmedRashed93,
If you would like to check what write_by_handle and read_by_handle, then I'd suggest you to check the following links:
bindings.cpp
https://bitbucket.org/OscarAcena/pygattlib/src/a858e8626a93cb9b4ad56f3fb980a6517a0702c6/src/bindings... https://bitbucket.org/OscarAcena/pygattlib/src/a858e8626a93cb9b4ad56f3fb980a6517a0702c6/src/bindings...
gattlib.cpp
https://bitbucket.org/OscarAcena/pygattlib/src/a858e8626a93cb9b4ad56f3fb980a6517a0702c6/src/gattlib.... https://bitbucket.org/OscarAcena/pygattlib/src/a858e8626a93cb9b4ad56f3fb980a6517a0702c6/src/gattlib....
gatt.h
https://bitbucket.org/OscarAcena/pygattlib/src/a858e8626a93cb9b4ad56f3fb980a6517a0702c6/src/bluez/at... https://bitbucket.org/OscarAcena/pygattlib/src/a858e8626a93cb9b4ad56f3fb980a6517a0702c6/src/bluez/at...
gatt.c
In bindings.cpp both write_by_handle and read_by_handle are defined under the "environment" of the Boost Python module. If you check gattlib.cpp, you will see that write_by_handle and read_by_handle end up using the gatt_write_char and gatt_read_char methods. These methods can be found in gatt.c.
If you read these files, you should be able to understand how these commands work and what they "handle". In case you need more help with this library I'd suggest you to contact the library's creator in https://bitbucket.org/OscarAcena/pygattlib/issues?status=new&status=open https://bitbucket.org/OscarAcena/pygattlib/issues?status=new&status=open since he'll be able to provide you more detailed information about how the library works.
Peter.
Community Manager
bindings.cpp
gattlib.cpp
gatt.h
gatt.c
Peter.
Community Manager
In one sentence you can say that a handle is the "access adress" for an attribute, so you get the value from it
You can find more information here:
https://www.safaribooksonline.com/library/view/getting-started-with/9781491900550/ch04.html https://www.safaribooksonline.com/library/view/getting-started-with/9781491900550/ch04.html
http://mike.saunby.net/2013/04/raspberry-pi-and-ti-cc2541-sensortag.html Michael Saunby: Raspberry Pi and TI CC2541 SensorTag
Flo1991
