Community
cancel
Showing results for
Search instead for
Did you mean:
YHOJO1
Edison: how to clear dirty bit on USB drive from Yocto linux
Jump to solution
When I mount USB drive (/dev/disk/by-partlabel/update) to loop device, the following message starts to show up in journalctl time to time. Once it starts, it continues to show up every time I mount the USB drive.
Edison kernel: FAT-fs (loop0): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
It goes away when I do scan and fix from Windows. Editing dirty bit by Windows software also fixes the problem.
But, I need to fix this problem from Edison by itself. I tried fsck.vfat with some combination of options, such as
fsck.vfat -aw /dev/mmcblk0p9
fsck.vfat -rw /dev/mmcblk0p9
fsck.vfat -arw /dev/mmcblk0p9
but I could not make it. Whichever I try, it just returns the following message, and the same FAT-fs message continues showing up in journalctl when I mount the USB drive.
dosfsck 2.11, 12 Mar 2005, FAT32, LFN
Logical sector size is zero.
Please tell me what I am wrong about.
Thank you
YHOJO1
Hi Peter,
Thank you for the information.
I was trying to use dd to write the edited data back to the volume and it looks working. The FAT-fs message is gone now.
Here is what I did:
1. Copy 17th block from /dev/mmcblk0p9 to a file (mmcblk0p9_block17.img),
root@Edison:~# dd if=/dev/mmcblk0p9 skip=16 count=1 of=mmcblk0p9_block17.img
2. Created another file (mmcblk0p9_edit01.img) by copying the block data other than the dirty-bit byte from the file,
root@Edison:~# dd bs=1c skip=0 count=65 if=mmcblk0p9_block17.img of=mmcblk0p9_edit01.img
root@Edison:~# printf '\x00' | dd bs=1c skip=0 count=1 seek=65 of=mmcblk0p9_edit01.img
root@Edison:~# dd bs=1c skip=66 seek=66 if=mmcblk0p9_block17.img of=mmcblk0p9_edit01.img
3. Then copied the edited data (mmcblk0p9_edit01.img) back to the /dev/mmcblk0p9.
root@Edison:~# dd if=mmcblk0p9_edit01.img seek=16 count=1 of=/dev/mmcblk0p9
Details are attached below. I hope this does not have unexpected side effects that I do not see so far.
1. Copy one block from /dev/mmcblk0p9 to a file (mmcblk0p9_block17.img),
1+0 records in
1+0 records out
root@Edison:~# hexdump -C mmcblk0p9_block17.img
00000000 eb 58 90 6d 6b 64 6f 73 66 73 00 00 02 08 20 00 |.X.mkdosfs.... .|
00000010 02 00 00 00 00 f8 00 00 20 00 40 00 00 00 00 00 |........ .@.....|
00000020 f0 ff 17 00 fd 05 00 00 00 00 00 00 02 00 00 00 |................|
00000030 01 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00000040 80 01 29 ac a9 83 55 45 64 69 73 6f 6e 20 20 20 |..)...UEdison |
00000050 20 20 46 41 54 33 32 20 20 20 0e 1f be 77 7c ac | FAT32 ...w|.|
00000060 22 c0 74 0b 56 b4 0e bb 07 00 cd 10 5e eb f0 32 |".t.V.......^..2|
00000070 e4 cd 16 cd 19 eb fe 54 68 69 73 20 69 73 20 6e |.......This is n|
00000080 6f 74 20 61 20 62 6f 6f 74 61 62 6c 65 20 64 69 |ot a bootable di|
00000090 73 6b 2e 20 20 50 6c 65 61 73 65 20 69 6e 73 65 |sk. Please inse|
000000a0 72 74 20 61 20 62 6f 6f 74 61 62 6c 65 20 66 6c |rt a bootable fl|
<p style="mar...
YHOJO1
I found this page(https://www.raymond.cc/blog/manually-reset-or-clear-dirty-bit-in-windows-without-chkdsk/2/ https://www.raymond.cc/blog/manually-reset-or-clear-dirty-bit-in-windows-without-chkdsk/2/).
And, I think I located the dirty bit, so far. I'm not sure if I can write the edited data back to the volume...
root@Edison:~# dd if=/dev/mmcblk0p9 count=17 2>/dev/null | hexdump -C
00000000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
000001b0 00 00 00 00 00 00 00 00 7b 42 36 fc 00 00 00 01 |........{B6.....|
000001c0 01 00 0b 03 d0 ff 10 00 00 00 f0 ff 17 00 00 00 |................|
000001d0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
000001f0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 aa |..............U.|
00000200 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
<<< 0x2000 = 8192, byte that includes 'dirty bit' is highlighted green >>>
00002000 eb 58 90 6d 6b 64 6f 73 66 73 00 00 02 08 20 00 |.X.mkdosfs.... .|
00002010 02 00 00 00 00 f8 00 00 20 00 40 00 00 00 00 00 |........ .@.....|
00002020 f0 ff 17 00 fd 05 00 00 00 00 00 00 02 00 00 00 |................|
00002030 01 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00002040 80 01 29 ac a9 83 55 45 64 69 73 6f 6e 20 20 20 |..)...UEdison |
00002050 20 20 46 41 54 33 32 20 20 20 0e 1f be 77 7c ac | FAT32 ...w|.|
00002060 22 c0 74 0b 56 b4 0e bb 07 00 cd 10 5e eb f0 32 |".t.V.......^..2|
00002070 e4 cd 16 cd 19 eb fe 54 68 69 73 20 69 73 20 6e |.......This is n|
00002080 6f 74 20 61 20 62 6f 6f 74 61 62 6c 65 20 64 69 |ot a bootable di|
00002090 73 6b 2e 20 20 50 6c 65 61 73 65 20 69 6e 73 65 |sk. Please inse|
000020a0 72 74 20 61 20 62 6f 6f 74 61 62 6c 65 20 66 6c |rt a bootable fl|
000020b0 6f 70 70 79 20 61 6e 64 0d 0a 70 72 65 73 73 20 |oppy and..press |
000020c0 61 6e 79 20 6b 65 79 20 74 6f 20 74 72 79 20 61 |any key to try a|
000020d0 67 61 69 6e 20 2e 2e 2e 20 0d 0a 00 00 00 00 00 |gain ... .......|
000020e0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
000021f0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 aa |..............U.|
00002200
Pedro_M_Intel
Hello vjou,
The package udisks should do the trick. I found out about this package in http://ubuntuforums.org/showthread.php?t=1821645 Ubuntu Forums and it work exactly as wish (but on my Ubuntu PC). I'm currently installing some dependencies on my Edison. You could try it too, so far I have had to install the following:
libxml2 - http://www.xmlsoft.org/downloads.html Downloads
libxslt - http://xmlsoft.org/XSLT/downloads.html Downloads
But I'm pretty sure I need some more and probably the dependencies have other dependencies, so it'll take a while. Meanwhile you could try it as well. You can find the source of udisks in:
http://www.freedesktop.org/wiki/Software/udisks/ udisks
Peter.
YHOJO1
Hi Peter,
Here is what I did:
1+0 records in
1+0 records out
<p style="mar...
YHOJO1
Just FYI,
Above was able to be done by directly writing a byte into the USB drive volume like below.
8257 is valid only for FAT32. If you look for other format, this page(https://www.raymond.cc/blog/manually-reset-or-clear-dirty-bit-in-windows-without-chkdsk/2/ https://www.raymond.cc/blog/manually-reset-or-clear-dirty-bit-in-windows-without-chkdsk/2/) may help you.
root@Edison:~# printf '\x00' | dd bs=1c seek=8257 count=1 of=/dev/mmcblk0p9
This is a scary operation to me. I still feel a little safer with the way described in /message/364480# 364480 my previous reply.
--- EDIT START 1/13/2016 ---
I'm sorry, but I was a little wrong about the value 8257. Now, I'm only sure that the value 8257 is valid for Edison's USB Mass Storage and NOT for all of FAT32 formats, because I recognized that the offset value to mount the FAT32 volume sometimes differs from 8192.
So, please do not try this without confirming the location of dirty bit.
--- EDIT END ---
