Following the steps https://software.intel.com/en-us/blinking-an-led-with-eclipse-ide-on-the-intel-edison-board IoT - Blinking an LED with the Eclipse* IDE | Intel® Developer Zone
I attempted to pursue the blinking of an LED on the mini breakout board. The web page hints at trouble: "Steps for the Intel® Edison module with mini breakout board may vary slightly."
Looking through the documentation for the breakout board, it seems clear that there is no way to blink the LEDs:
"The Intel® Edison Breakout Board has two LEDs. There is no direct control over these LEDs, so they are described here for informational purposes. "
Hi Mike-SYR,
Yes, the Mini-Breakout board doesn't have a built-in LED for these purposes so you'll have to add external circuitry if you want to blink a LED using the Mini-Breakout Board. I suggest you to take a look at the thread below, where this is already discussed.
PabloM_Intel
Hi Mike-SYR,
PabloM_Intel
Hi PabloM_Intel
Thanks for that.
Since this is all web-based, wouldn't it be easy to update the original page?
Cheers,
Mike
Hi Mike-SYR,
Thank you for your feedback. Just one question, do you mean the site that you were using to follow the Blink example? Or the documentation for the Breakout Board?
PabloM_Intel
Hi PabloM_Intel
The web page of the example -that's where, IMO, new users of the board would/should go first.
(Yes, many will still overlook this, but at least it'd be documented and these users can be sent there)
1. A warning upfront, highlighted somehow, about the mini's shortcomings in this regard.
2. Followed, perhaps, by a link to a page on which is a schematic (maybe with photo) of a suitable circuit.
Thanks for your consideration.
Mike
Hi Mike-SYR,
Thank you for your feedback, we will pass this information to the team in charge of these changes.
PabloM_Intel
