Hi, I just upgraded the Yocto firmware to edison-image-ww25.5-15, by extracting the image, copying all the files into the Edison USB storage, logged in to Edison via the serial post and entered the command "reboot ota". After that, Edison seem to be getting an error "MMC: block number 0x7842843a exceeds max(0x748000)" while booting, and try to boot over and over gain. This is the repeating output I get:
PSH KERNEL VERSION: b0182727
WR: 20104000
SCU IPC: 0x800000d0 0xfffce92c
PSH miaHOB version: TNG.B0.VVBD.0000000c
microkernel built 23:15:13 Apr 24 2014
******* PSH loader *******
PCM page cache size = 192 KB
Cache Constraint = 0 Pages
Arming IPC driver ..
Adding page store pool ..
PagestoreAddr(IMR Start Address) = 0x04899000
pageStoreSize(IMR Size) = 0x00080000
*** Ready to receive application ***
U-Boot 2014.04 (Aug 20 2014 - 16:08:32)
Watchdog enabled
DRAM: 980.6 MiB
MMC: tangier_sdhci: 0
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 0
Target:blank
Partitioning already done...
reading ota_update.scr
I stop autoboot and did "run do_ota" ad the boot prompt, but I get the same error "reading ota_update.scr MMC: block number 0x7842843a exceeds max(0x748000)". I tried to flash Edison with ./flushall.sh, but it doesn't recognize the board and times out, since the board is not booting. Of the same reason Edison does not show up as an USB storage anymore.
Before upgrading, I had not problem, everything worked as it should. I'm using an older HP ElitBook 8440p with Ubuntu 10.04 for this project.
The reason I choose to upgrade to edison-image-ww25.5-15 (2.0) and not to the latest edison-iotdk-image-280915 (2.1) is that the later it too big (1Gb) to fit in the Edison USB storage (0.8Gb).
I would be very grateful if someone can give med some advice on how to proceed with this. I hope the device is not beyond rescue.
Hello orjan,
I see something might have gotten wrong while flashing the last time. In that case I'd suggest you to use Flash Tool Lite to flash your board, with this tool you don't have to transfer the image files to your Edison so you could try the last image. You can find Flash Tool Lite as well as a guide on how to use it on https://software.intel.com/en-us/iot/hardware/edison/downloads IoT - Intel® Edison Board Download | Intel® Developer Zone.
Peter.
Hello orjan,
Peter.
Peter, thanks. I wasn't able to run Flash Tool Lite on the older laptop with the Ubuntu 10.04, but tried it at home later on on a Linux Mint 14, and it worked. So I guess when nothing else works, Flash Tool Lite is your friend. Now the fun begins.
Thanks again!
/Örjan
