Intel® Makers
9881 Discussions
Edison occasionally hangs trying to suspend
JRoew
I'm using release 2.1 ww18-15. Most of the time when I suspend the edison (echo mem > /sys/power/state), suspend works. I can wake the edison back up using the console (ttyMFD2).
Occasionally, when I suspend the edison it hangs and remains unresponsive until the watchdog fires and resets the system.
To debug, I added "no_console_suspend=1" to the kernel arguments in u-boot. Then I added a printk in drivers/base/power/main.c:dpm_suspend() before device_suspend() is called for each device.
I compared a list of all devices being suspended when sleep fails and when sleep succeeds and the list is the same until it hangs in the failure. The last device being suspended before the hang is "mmc0:0001".
Here's the end of the output when suspend fails:
suspending device mmcblk0p2
suspending device mmcblk0p1
suspending device 179:0
suspending device mmc0:0001
Here's an excerpt of the corresponding output when suspend works:
suspending device cooling_device0
suspending device hwmon5
suspending device thermal_zone4
JRoew
I believe this is a bug in the Intel code added for RPMB partition support. The call to mmc_claim_host() blocks sometimes because sometimes the mmc host is still claimed.
This is the commit that added the code:
commit 9e36a6d9898a3bc9433778a42d1c8dbf9e522299
Author: Rodriguez Fabien <</span>mailto:fabienx.rodriguez@intel.com fabienx.rodriguez@intel.com>
Date: Wed Oct 29 09:54:49 2014 +0100
mmc: rpmb partition support
This patch contains all bugs fixing for supporting RPMB partition
in MMC driver side.
Signed-off-by: Rodriguez Fabien <</span>mailto:fabienx.rodriguez@intel.com fabienx.rodriguez@intel.com>
This is the specific code that is causing a problem in drivers/mmc/card/block.c:
static int mmc_blk_suspend(struct mmc_card *card)
struct mmc_blk_data *part_md;
struct mmc_blk_data *md = mmc_get_drvdata(card);
if (md) {
mmc_queue_suspend(&md->queue);
list_for_each_entry(part_md, &md->part, part) {
mmc_queue_suspend(&part_md->queue);
+ if (part_md->part_type ==
+ EXT_CSD_PART_CONFIG_ACC_RPMB) {
+ * RPMB partition is accessed by API directly.
+ * Driver need to set a flag when suspending
+ * MMC block device to notify API that the
+ * accessing of RPMB partition needs to be
+ * stopped
+ mmc_claim_host(card->host);
+ part_md->flags |= MMC_BLK_SUSPENDED;
+ mmc_release_host(card->host);
return 0;
JRoew
I believe that I have found the root cause. There was a bug in the kernel that was leaking the mmc host claim. A commit to the kernel after 3.10 fixes the issue for me. The hang is rare on the stock intel 2.1 release. It only happened one in ten boots or less but suspend would hang seven out of ten boots on my build with additional services. After I backported the following fix, the system has successfully suspended 200+ times in a row.
This is the commit that needs to be backported to the 3.10 linux kernel to prevent suspend from hanging on the edison:
https://git.kernel.org/cgit/linux/kernel/git/stable/linux-stable.git/commit/?id=f662ae48ae67dfd42739... https://git.kernel.org/cgit/linux/kernel/git/stable/linux-stable.git/commit/?id=f662ae48ae67dfd42739...
