Intel® Makers
9882 Discussions
Edison reboot by watchdog
eyuan2
I meet a strange problem from edison
I find out my edison will reboot automatically at a interval time.
Before it reboot again.I checked the crashlog file in /home/root/crashlog_00007.
and find out it was caused by kernal watchdog reset.
But i don't think i every touched anything in kernal.
Does anyone know the reason.
I now have to reflash the board if i want to play with it.
Below is the crashlog_00007
Below are the information that i get if i open the crashfile from crashlog_00007
Community Manager
Unfortunately, I can't reproduce this behavior on my board and see the crashlog file but from the look of the pictures you attached it seems there was a kernel modification of some other kind of configuration. The Edison shouldn't reboot automatically as you describe. The Edison can also reboot automatically if it isn't receiving enough power, make sure to power it correctly.
Additionally, there's a new image available for download here https://software.intel.com/en-us/iot/hardware/edison/downloads https://software.intel.com/en-us/iot/hardware/edison/downloads . Flash your Edison with this new image and let us know if this behavior persists.
Sergio
eyuan2
Hey Sergio
Yes, I can solve the problem by reflash the system. and I already did that, just curious about the root reason of it.
The power system is OK. Not sure it's because i didnot turn it off by command or it's because some file are damaged when i update something?
Eric
Community Manager
The Watchdog timer can be used to trigger a reset in the event that the system has become unresponsive.
In your case, it's possible that something made the OS crash, thus rebooting the Edison.
Sergio
eyuan2
Yes.I think it's because i upload something or some file was damaged while i unplug the power supplier.
I also find out if i update the nodejs to v0.12.1,then i cannot connect my edison to XDK through ssh while i can control it by putty through SSH
