Community
cancel
Showing results for
Search instead for
Did you mean:
KZama2
Edison time does not sync with PC time
Hi all!
I followed every instructions given to setup my Intel Edison, but when i choose "Sync PC time w/clock on target device" at "Manage your daemon/IoT device" button in Intel XDK 2571,
the date appear to be correct but the time is lagging hours back. Any idea?
Additional info:
Dell studio 1555 - window 7 Ultimate - 32-bit
(UTC+08:00) Kuala Lumpur, Singapore.
Thx in advance!
Matthias_H_Intel
it's pretty much in sync - just the timezone isn't synced but given in UTC
Sergio_A_Intel
This may be useful as well http://www.thegeekstuff.com/2010/09/change-timezone-in-linux/ How To: 2 Methods To Change TimeZone in Linux
Sergio
Matthias_H_Intel
Sergio
although you can set "manually" as described in the link I'd rather recommend using
# timedatectl -h
timedatectl [OPTIONS...] COMMAND ...
Query or change system time and date settings.
-h --help Show this help message
--version Show package version
--no-pager Do not pipe output into a pager
--no-ask-password Do not prompt for password
-H --host=[USER@]HOST Operate on remote host
-M --machine=CONTAINER Operate on local container
--adjust-system-clock Adjust system clock when changing local RTC mode
Commands:
status Show current time settings
set-time TIME Set system time
set-timezone ZONE Set system time zone
list-timezones Show known time zones
set-local-rtc BOOL Control whether RTC is in local time
set-ntp BOOL Control whether NTP is enabled
KZama2
Hi all!
thanks alot for the reply guys! it really helps me figure out how to solve the issue i encountered.
I tried to get hold of UTC file with UTC+0800 but unfortunately rest me unsettle.
so what i did is ls into zoneinfo file and look for suitable time zone which turn out to be in Etc/GMT-8.
and now its working!
