Community
cancel
Showing results for
Search instead for
Did you mean:
dvian
Edison wifi help
Jump to solution
hello somebody,
I have a big problem with my intel edison, so I come to you to ask you for help.
I arrived more to connect my wifi is edison this is a big problem.
I redid the image is its not working, I try to connect to a USB port is its network does not work either,
So what to do ??
so I can not login with intel xdk since no wifi connection ...
the problem and also that I can not install the lib Mraa
I also reformat all edison is complementary to nothing has changed
by hazar's what I can install an Arduino ethernet Schield above?
thank you for your reply
vianney login: root
Password:
root@vianney:~# configure_edison --wifi
Configure Edison: WiFi Connection
Scanning: 1 seconds left
0 : Rescan for networks
1 : Exit WiFi Setup
2 : Manually input a hidden SSID
3 : SFR_ED30
Enter 0 to rescan for networks.
Enter 1 to exit.
Enter 2 to input a hidden network SSID.
Enter 3 to choose SFR_ED30: 3
Is SFR_ED30 correct? [Y or N]: y
Initiating connection to SFR_ED30. Please wait...
Attempting to enable network access, please check 'wpa_cli status' after a minute to confirm.
Not connected. Something went wrong.
root@vianney:~#
Pedro_M_Intel
Hello vianney,
Since you built the image that is currently running on your Edison, it could happen that the wpa_supplicant service is not running. Show us a screen shot of the following commands:
systemctl status wpa_supplicant
ls /lib/systemd/system | grep wpa_supplicant
But if you wish to format your Edison, I suggest you to reflash the board to the latest image with Flash Tool Lite. Both the Edison's image and Flash Tool Lite can be found in https://software.intel.com/en-us/iot/hardware/edison/downloads Intel® Edison Downloads. You will also find a guide on how to use Flash Tool Lite on the same link.
Peter.
Pedro_M_Intel
Hello vianney,
Peter.
dvian
Hey Peter
root@vianney:~# systemctl status wpa_supplicant
● wpa_supplicant.service - WPA supplicant service
Loaded: loaded (/lib/systemd/system/wpa_supplicant.service; enabled)
Active: active (running) since Mon 2016-01-11 18:52:07 UTC; 19min ago
Process: 253 ExecStartPost=/bin/systemctl start wpa_supplicant_p2p_event (code=exited, status=0/SUCCESS)
Process: 191 ExecStartPost=/bin/systemctl start wpa_supplicant_wlan0_event (code=exited, status=0/SUCCESS)
Main PID: 189 (wpa_supplicant)
CGroup: /system.slice/wpa_supplicant.service
└─189 /usr/sbin/wpa_supplicant -u -c/etc/wpa_supplicant/wpa_suppli...
Jan 11 18:52:07 vianney systemd[1]: Started WPA supplicant service.
root@vianney:~#
root@vianney:~# ls /lib/systemd/system | grep wpa_supplicant
wpa_supplicant_p2p_event.service
wpa_supplicant_wlan0_event.service
root@vianney:~#
I finally by repeating an image.
I use phone flash tool as it is a very good software and I thank intel to have developed.
I held Peter thank you very much because you are always there when you have a concern so thank you very much
Vianney
of
France
Pedro_M_Intel
I'm glad to be of help and to hear that you were able to solve your issue, if you ever have any other issue, don't hesitate to come back to the community, we will do our best to help you.
Peter.
玉谭
I still have the same problem with vianney ,and I still cannot soulve it.
My problem is that if I connect edison board to a totally new wifi,it does work well.
But when I connect to a wifi that edison connected before,I tried a lot of times to connect,but still cannot connect successfully.
It bothers me two days,I wish @Intel_Peter or somebody can help out.
Pedro_M_Intel
Hi warrior,
Could you please let me know which image are you using? Did you make sure to flash the latest version? It can be found here: https://software.intel.com/en-us/iot/hardware/edison/downloads
Try flashing your board to the latest version and let us know if the issue persists.
-Peter.
