Intel® Makers
9881 Discussions
Edison will not boot. How to recover data?
aedwa2
New Contributor III
My Edison has been working in my product for a couple of years. It worked yesterday but might have had the power removed during shutdown. When I went to recover my data this morning it will not boot. No error messages. Is there any way to recover my data file? I logged about an hour of data and need to get it.
PSH KERNEL VERSION: b0182929
WR: 20104000
SCU IPC: 0x800000d0 0xfffce92c
PSH miaHOB version: TNG.B0.VVBD.0000000c
microkernel built 10:14:01 Jan 13 2015
******* PSH loader *******
PCM page cache size = 192 KB
Cache Constraint = 0 Pages
Arming IPC driver ..
Adding page store pool ..
PagestoreAddr(IMR Start Address) = 0x04899000
pageStoreSize(IMR Size) = 0x00080000
*** Ready to receive application ***
U-Boot 2014.04 (Feb 11 2015 - 20:13:05)
Watchdog enabled
DRAM: 980.6 MiB
MMC: tangier_sdhci: 0
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 0
Target:blank
Partitioning already done...
Flashing already done...
GADGET DRIVER: usb_dnl_dfu
reading vmlinuz
5280608 bytes read in 334 ms (15.1 MiB/s)
Valid Boot Flag
Setup Size = 0x00003c00
Magic signature found
Using boot protocol version 2.0c
Linux kernel version 3.10.17-yocto-standard (andrew@Compilefarm) # 1 SMP PREEMPT Wed Feb 11 22:21:05 CST 2015
Building boot_params at 0x00090000
Loading bzImage at address 00100000 (5265248 bytes)
Kernel command line: "rootwait root=PARTUUID=012b3303-34ac-284d-99b4-34e03a2335f4 rootfstype=ext4 console=ttyMFD2 earlyprintk=ttyMFD2,keep loglevel=4 g_multi.ethernet_config=rndis systemd.unit=multi-user.target hardware_id=00 g_multi.iSerialNumber=3a6af05b4217973936d6852d9dde7ee6 g_multi.dev_addr=02:00:86:de:7e:e6"
Starting kernel ...
Andriy_S_Intel
First of all, add ignore_loglevel to kernel command line (there is a special environment variable even for that, it has debug in the name, but I don't recall right now full name of it). Add it and see what kernel will write.
aedwa2
New Contributor III
And how do I add anything to the kernel command line if it won't boot? I hope there is an answer because if I could write, I could probably read and that is what is important. I need the data that is on the Edison.
Andriy_S_Intel
I'm too lazey to explain details, but you just simple need to interrupt U-Boot to get into its "shell" and modify environment variable. After that you have two options: just boot, or save and boot.
Community Manager
Hello allene,
Thank you for your interest in the Intel® Edison Breakout Board.
I'm sorry to inform you that there isn't a way to retrieve the data from a board that doesn't boot.
If you have any other question, don't hesitate to contact us.
Andres V.
aedwa2
New Contributor III
0andriy
Can you give me a link or a hint on how to get into U-Boot shell?
Allen
Andriy_S_Intel
  • Connect your board via serial interface to the PC
  • Open terminal application on PC side (in Linux picocom, in Windows putty)
  • Reset or power on your Edison board
  • When it will starts countdown (for 1 second) you hit space to interrupt it
  • Now you are in U-Boot command line.
aedwa2
New Contributor III
0andriy
I put the Edison in boot mode and have spent about an hour Googling trying to figure out how to put the append the "ignore_loglevel" parameter. I can find how to add it in the file system but not how to add it from the boot command line. I can't figure it out. I think it should not be this hard to figure it out. I am pretty sure I used to do it with RadHat 4 but that was 20 years ago. I would appreciate some help.
Andriy_S_Intel
allene kirjoitti:
0andriy
=> grep loglevel
bootargs_debug=loglevel=4
=> setenv bootargs_debug 'ignore_loglevel'
=> boot
aedwa2
New Contributor III
Thank you 0andriy
This s what I get
boot > grep loglevel
boot > setenv bootargs_debug 'ignore_loglevel'
boot > boot
Target:blank
reading vmlinuz
5280608 bytes read in 373 ms (13.5 MiB/s)
Valid Boot Flag
Kernel command line: "rootwait root=PARTUUID=012b3303-34ac-284d-99b4-34e03a2335f4 rootfstype=ext4 console=ttyMFD2 earlyprintk=ttyMFD2,keep ignore_loglevel g_multi.ethernet_config=rndis systemd.unit=multi-user.target hardware_id=00 g_multi.iSerialNumber=3a6af05b4217973936d6852d9dde7ee6 g_multi.dev_addr=02:00:86:de:7e:e6"
Starting kernel ...
Then after a minute or so it starts over. Now what?
WR: 20104000
Watchdog enabled
DRAM: 980.6 MiB
In: serial
Out: serial
Err: serial
Target:blank
reading vmlinuz
5280608 bytes read in 392 ms (12.8 MiB/s)
Valid Boot Flag
Starting kernel ...
Andriy_S_Intel
Okay, it means you have quite corrupted boot partition. Depends on how valuable data is there (on eMMC) and how much time you have, you may try a hard way. I.e. update U-Boot, prepare an image with new kernel and initramfs on SD card, boot it and mount partitions on eMMC. Depending on the result it might be possible to retrieve valuable data.
