Intel® Makers
9872 Discussions
Edison with breakout board won't save program after powering down.
KKyle
I have the intel edsion arduino breakout board. I can upload sketches from arduino and that seems to be working fine, but after powering down the board- either by unplugging it completely or holding down the onboard power button, the program doesn't run after powering the board back up like it does with my arduino uno. I'm new to Edison so maybe I'm making a simple mistake, any help would be appreciated .
Carlos_M_Intel
Hi kylegray,
This is happening in the newer releases and we have already reported this behavior. Right now, there are some methods you can use in order to run the sketch after every boot,
https://software.intel.com/en-us/blogs/2015/08/01/procedure-to-autostart-the-arduino-sketch-on-ediso... Procedure to Autostart the Arduino Sketch on Edison | Intel® Developer Zone
Charlie
Carlos_M_Intel
Hi kylegray,
Charlie
